ᐅ Which screws are suitable for assembling Ikea Metod base cabinets?
Created on: 5 Jan 2022 09:12
kainso
I am planning to assemble some Ikea Metod base cabinets and am currently in the process of ordering the appropriate screws. Unfortunately, I have noticed that the screws supplied often are not ideal or sometimes missing. My question is: Which screws are best suited for the proper and stable assembly of Ikea Metod base cabinets?
I am particularly interested in several points:
- Which types of screws (length, diameter, material) are most commonly used for joining the individual components?
- Are there any screws that work especially well with the furniture materials (particleboard, MDF)?
- Which screws are recommended for mounting the plinth and possibly for wall attachment?
I would appreciate detailed information or also tips on common mistakes when choosing screws. Thanks in advance!
Juan31
6 Jan 2022 09:27
kainso schrieb:
Are there screws with higher strength that are more durable but still fit well into the threads of the mounting plate?
Loose hinge attachments are usually not caused by the quality of the screws, but rather by the threaded inserts used or the preload tension.
Ikea uses metal threaded inserts in the panels, which are generally quite sturdy. If these inserts are damaged, it can result in a loose fit.
If the threads in the mounting plate are intact, it is recommended to use screws made of quality steel with a strength class of 8.8 or higher. These are often available at hardware stores labeled as machine screws with the corresponding specifications.
When tightening, be careful not to exceed the specified torque to avoid damage, while still ensuring a secure fit.
If the problem occurs frequently, replacing the threaded inserts may be necessary, although this is usually not required.
klo61
7 Jan 2022 10:02
One final recommendation for everyone choosing screws for Ikea Metod cabinets:
- Always use adequately sized main screws (4.5x50 mm (3/16x2 inches) is a good standard).
- Use galvanized or stainless steel screws, as kitchens have specific moisture requirements.
- For hinges and drawer slides, use M4 machine screws with a length of 16-20 mm (5/8–3/4 inches).
- Pre-drilling is not absolutely necessary for particleboard but is recommended if unsure or for a precise fit.
- When attaching to walls, always use appropriate anchors and screws, depending on the wall material.
A good tool with torque control helps avoid mistakes. Overall, Ikea provides decent screw kits, but using high-quality replacements ensures a more secure and durable assembly.
I hope this summary helps everyone here in the thread.
