Good morning everyone, I am currently planning the installation of an Ikea Metod kitchen and am unsure which screws are best suited for this. My questions are as follows:
- Which types of screws (wood screws, particleboard screws, machine screws, etc.) are most suitable for connecting the Metod carcasses to ensure stability?
- Are there specific lengths or diameters that should definitely be considered, especially since the carcasses are made of particleboard with a melamine-coated surface?
- Should galvanized screws be used to prevent rust, or are standard screws sufficient?
- Are there screws that put less strain on the material and prevent long-term pull-out?
I want to avoid using screws that become loose after a few months or damage the surface. I would appreciate concrete recommendations or tips on which screws are better to avoid.
One more addition from my side: Since IKEA kitchens are often located in more humid areas (kitchen, sometimes dishwater, etc.), you should check the screws for moisture resistance. Galvanized screws are usually sufficient, while stainless steel is more expensive but especially durable.
When screwing, work carefully to protect the material and use the torque limiter on your cordless drill; this extends the life of the connection.
When connecting carcasses with multiple holes, always tighten diagonally to prevent warping.
Also consider whether you want to reinforce the connections with furniture connector dowels (cylindrical dowels). These distribute forces even better and provide greater stability.
Dilen schrieb:
Also consider whether you want to reinforce the joints with dowels (cylindrical dowels) as well.Exactly, that was also my recommendation. While it’s not absolutely necessary for Ikea Metod cabinets, if you want maximum stability, Festool or wood dowels are an excellent addition.
A minor drawback is that these dowel systems require precise drilling and a bit more effort.
However, the result is significantly less risk of screws pulling out and greater overall rigidity.
Thank you all for the detailed and practical advice.
For me, it is now clear: use zinc-plated chipboard screws with a diameter of 4 – 4.5 mm (0.16 – 0.18 inches) and a length of 40–50 mm (1.6 – 2 inches), pre-drill holes, use flat-head screws, and, if necessary, reinforce with furniture connector dowels.
The screws should have partial threads to protect the surface and ensure longer durability.
I also took note of tightening with a torque-limited cordless drill.
I will also reinforce the joints with the Ikea brackets, so overall it should be very sturdy.
Thanks again to everyone who contributed here!
warrenka571 Nov 2024 08:45I agree – it is often observed that without a firm tightening force, the screws do not grip properly and may loosen later.
The stability also depends on how precisely the assembly is carried out.
