ᐅ What tools do you need to assemble the Ikea Platsa?
Created on: 14 Aug 2024 09:17
Lienzo1
Lienzo1
14 Aug 2024 09:17
Hello everyone, I’m planning to assemble an Ikea Platsa wardrobe soon, but I’m not sure which tools I specifically need for it. Since Ikea usually provides a simple Allen key, I wonder if that’s really enough or if additional hand tools should be kept ready to make the assembly as efficient and error-free as possible. I want to avoid having to keep searching for tools during the build or getting stuck because the right tool isn’t available. From your experience with Ikea Platsa, which tools are absolutely essential? Are there any accessories or aids that significantly simplify the assembly? Thanks in advance for your tips!
Nabla64
14 Aug 2024 09:44
Good question, Lienzo1! For assembling the Ikea Platsa, I always recommend having the following set of tools ready:
- Phillips screwdriver (PH2), as some connections are better secured with this than with the included hex key.
- A cordless drill with hex bits to drive the screws faster and with less effort.
- A hammer or rubber mallet to gently fit dowels or back panels without damaging the wood.
- A utility knife for removing packaging or for precise trimming of small areas.
My tip: Don’t skip the included hex key, but especially use the cordless drill for screwing. It saves time and frustration. Just make sure to set the appropriate torque to avoid over-tightening or stripping the screws. Good luck!
Domau0
14 Aug 2024 10:12
I’m going into some detail here because assembling the Platsa system can be quite tricky. The combination of screws and wall plugs requires careful preparation:
- In my opinion, a good Phillips screwdriver is essential since you often have to make manual adjustments, especially in corners or when attaching the back panels.
- Cordless drills are great, but be sure to use a reduced torque setting. Ikea particleboard is delicate, and screws driven too deep can easily damage the material.
- For the wall plugs, I recommend a small claw hammer. A regular hammer or rubber mallet can work, but a claw hammer is usually more versatile.
- Something often overlooked: a folding ruler or tape measure to ensure the cabinets are mounted straight and precisely on the wall. This is especially important with Platsa fronts to avoid problems later on.
I’d like to know if you plan to have the cabinet completely freestanding or attached to the wall? This will determine whether you also need a level and longer screws.
Lienzo1
14 Aug 2024 11:03
Domau0 schrieb:
I’d like to know if you plan to have the cabinet completely free-standing or fixed to the wall? This also affects whether you need a spirit level and longer screws.
Thanks for asking! Actually, the Platsa system will be fixed to the wall because I want to use it as a room divider and ensure stability. So I think using a spirit level and longer screws makes sense. Are there any other special considerations for wall mounting regarding the tools? For example, when pre-drilling or choosing the anchors?
Nabla64
14 Aug 2024 11:35
Lienzo1 schrieb:
Are there any special considerations regarding tools for wall mounting? For example, when pre-drilling or choosing anchors?
Yes, definitely! For wall mounting, you absolutely need:
- A drill, ideally a drill machine or cordless screwdriver with a drilling function.
- Appropriate drill bit sizes, depending on the wall type. For concrete walls, use a masonry bit; for drywall, use special cavity anchors.
- Anchors suitable for the specific wall type – expansion anchors or sleeve anchors for masonry, cavity anchors or metal toggle bolts for drywall.
- A spirit level to ensure the cabinet is aligned precisely is essential.
Without the right tools and materials, the mounting can become unstable – so it’s better to prioritize quality and proceed carefully.
nolan
14 Aug 2024 12:01
Summary: Allen key (included with the Platsa), Phillips screwdriver, cordless drill, hammer, spirit level, and drill bits with suitable wall plugs for wall mounting. That’s all you need.
