Hello everyone, I’m planning to assemble an Ikea Platsa wardrobe soon, but I’m not sure which tools I specifically need for it. Since Ikea usually provides a simple Allen key, I wonder if that’s really enough or if additional hand tools should be kept ready to make the assembly as efficient and error-free as possible. I want to avoid having to keep searching for tools during the build or getting stuck because the right tool isn’t available. From your experience with Ikea Platsa, which tools are absolutely essential? Are there any accessories or aids that significantly simplify the assembly? Thanks in advance for your tips!
I just wanted to add that a small tool like a pair of pliers can be very useful during assembly. If a dowel or a small part gets stuck at an angle, you can quickly make adjustments. Also, when mounting on the wall, it’s worth having a Spax screwdriver bit on hand in case you want to attach something in a creative way 😉 Good luck—the Platsa is very stable if you follow the tips!
One more practical tip: When using a cordless drill, be sure to start with a low torque setting. Otherwise, you might drive the supplied screws in too deeply. Taking your time when screwing is worth it. And for an even gentler approach, use a small cloth to protect surfaces when working with a hammer or other tools.
