ᐅ Which tools are essential for assembling IKEA Metod kitchen cabinets?
Created on: 30 Nov 2023 08:37
fupar66
fupar66
30 Nov 2023 08:37
I am currently planning the installation of my new IKEA Metod kitchen and want to prepare as best as possible for the assembly. My main question is: Which tools are truly essential for installing IKEA Metod kitchen cabinets?
I am especially interested in which hand tools or power tools make the biggest difference in everyday use, which ones are absolutely necessary, and whether there are any tools that are often underestimated but can save a lot of time or prevent difficulties.
I already own a cordless drill, but I’m not sure if that alone is enough or if special tools are needed for the panels, rails, and fronts.
For those who have already assembled this kitchen: What would you recommend and what would you advise against? Thanks in advance for your experiences and tips!
Tobias
30 Nov 2023 12:29
A cordless drill is definitely essential. Along with that, a spirit level, a tape measure, and preferably a small hammer. You really don’t need much more for the Metod furniture.
TEOZAR
30 Nov 2023 14:08
I think your question is very well formulated and important because many people underestimate how precise the installation needs to be.
Besides the cordless screwdriver, I recommend:
- A good Phillips bit for the screwdriver (Torx bits are usually not necessary; IKEA mainly uses Phillips)
- A spirit level, as Tobias already mentioned, to align the cabinets precisely
- A tape measure or folding rule for accurate measurements, especially during installation and alignment
- A rubber mallet to position parts gently
What is often forgotten is a stable work surface or assembly table, which makes the work much easier and helps prevent damage.
If you want to be precise, a protractor can also be useful, for example when working with countertops or back panels.
Important: Make sure your cordless screwdriver has a torque setting so you don’t overtighten the screws and damage the material.
nonpra
1 Dec 2023 09:52
In addition to the tools mentioned, I would also recommend having a small ladder on hand when installing wall cabinets. Gloves are also useful, especially when working with particle boards or metal fittings.
likuken
1 Dec 2023 11:43
I think calling these tools "indispensable" is a bit exaggerated. Sure, you need a cordless drill and a tape measure, and that’s basically enough. Lots of extras like a rubber mallet or a try square are more for professionals or very meticulous DIY enthusiasts.
fupar66 schrieb:
ich plane gerade die Montage meiner neuen IKEA Metod Küche und möchte mich bestmöglich auf den Zusammenbau vorbereiten.
You can also finish quickly with fewer tools if you’re not aiming for perfection. It’s better to take the time to read the instructions carefully than to buy too many tools.
warrenka57
1 Dec 2023 17:27
I can imagine that this all might seem overwhelming if you don’t build furniture often or don’t have a workshop.
What helped me was making a list beforehand and checking off each step in the instructions. The cordless drill made many tasks easier, but I also kept a hand hammer and a spirit level nearby.
TEOZAR schrieb:
Important: Make sure your cordless drill has a torque setting so you don’t overtighten the screws and damage the material.
That was a tip I really underestimated. My first cordless drill was quite powerful, and I ended up enlarging some holes.
So: think carefully about which tools you really know how to use and want to work with, instead of buying everything.
