ᐅ Which installation materials are essential for assembling the IKEA Metod kitchen system?
Created on: 6 Feb 2020 08:07
Bikomar
Bikomar
6 Feb 2020 08:07
Hello everyone, I am currently planning the installation of the IKEA Metod kitchen system and want to prepare as best as possible, especially regarding the essential assembly materials. My specific question is: "Which assembly materials are absolutely necessary for installing the IKEA Metod system to ensure a stable and secure kitchen furniture setup?" I am interested in all essential tools, fasteners, and mounting kits that should definitely be available, covering cabinet assembly, wall mounting, as well as the installation of doors and interior fittings. Are there any items that IKEA does not provide as standard but that I should definitely obtain? Thanks in advance for your recommendations and tips!
JORGERON
6 Feb 2020 08:25
Absolutely essential are a cordless drill, the supplied connecting screws for the carcasses, and a good spirit level. Additionally, wall plugs and suitable screws for wall mounting are needed, depending on the wall material.
LOJOPAR
6 Feb 2020 08:43
In addition to JORGERON, I would like to provide a brief overview:
- A cordless drill with various bits (Phillips, Torx) is essential, as most screws require different heads.
- IKEA’s Metod assembly kits typically include cam connectors and elongated screws, which are mandatory.
- For wall mounting: Depending on the wall material (concrete, drywall, tiles), appropriate anchors are necessary. For drywall with metal stud framing, I recommend metal expansion anchors.
- An assembly kit with door dampers is advisable for smoother door closing.
- For baseboard installation, you need base feet with screws.
If you want exact article numbers, I can add them to the list.
Layla
6 Feb 2020 09:01
I find this topic really interesting because I recently assembled the Metod myself, and it wasn’t always easy to keep track of everything. What helped me the most was to get all the right installation materials in advance. For wall mounting, for example, you should always use good quality anchors and longer screws, since safety is always the top priority in a kitchen! And even though IKEA supplies a lot of the parts, brackets or special hangers are often missing to secure the cabinets more firmly.
Brian
6 Feb 2020 09:19
Let me explain the basics: For IKEA Metod, the most important components are the connecting screws (often cam locks and dowels) that come included. You will also need suitable wall plugs for the walls, which IKEA does not supply. For the interior fittings or doors, you will require screwdrivers or a cordless drill with the appropriate bits. My recommendation: plan for a small additional assembly kit, such as corner braces for extra stability, which are not always included in the standard sets.
Takutau
6 Feb 2020 10:07
I would like to go into more detail, as this topic is quite extensive. When assembling the IKEA Metod kitchen, you need to clearly differentiate between three areas: cabinet assembly, wall mounting, and door/drawer installation.
- For the cabinets, cam fittings, dowel screws, and slotted screws are central. These are usually all included in the delivery and are perfectly coordinated.
- However, wall mounting requires special attention: depending on the wall type, specific anchors are necessary (nylon anchors, metal expansion anchors, heavy-duty anchors, etc.). I strongly recommend thoroughly checking the wall beforehand.
- Additionally, a powerful cordless screwdriver with variable torque control is needed to tighten the screws properly without damaging the material.
- Regarding the doors, door dampers and soft-close hinges are highly recommended if they are not already included.
Many also underestimate the importance of a spirit level for precise alignment. Poor leveling here will cause a lot of trouble later on.
My tip: create a checklist before starting the assembly and separately obtain any potentially needed hanging brackets and special fastening materials, as IKEA often does not pack these together.
