ᐅ What is the best way to maintain the surfaces of Ikea Hemnes furniture?
Created on: 18 Dec 2021 09:17
glaro
glaro
18 Dec 2021 09:17
Hello everyone, I am currently facing the challenge of finding the best surface care for my Ikea Hemnes cabinet. Since Hemnes is known to be made from solid pine and is often finished with either lacquer or oil-wax, I am wondering which care products or methods are most suitable to protect the surface while preserving the natural texture and color of the wood. Specifically, I am interested in whether you have experience with special furniture waxes, oils, or cleaners that are low in harmful substances and easy to use for home maintenance. Are there any tips for application to avoid unpleasant residues or even damage? I look forward to your informed opinions and practical advice!
nonere
18 Dec 2021 11:43
Surface care for Ikea Hemnes furniture should primarily take into account the characteristics of pine wood and the specific finish. Hemnes pieces are typically coated with either a lacquer seal or a thin layer of oil wax, which simplifies maintenance but also comes with certain limitations. For lacquered surfaces, I recommend using a mild microfiber cloth along with a neutral furniture cleaner that contains no solvents or silicones. These products clean without damaging or dulling the lacquer. For oil-waxed surfaces, occasional refreshing with a color-neutral furniture wax is advisable. It is important to apply a thin layer and, after sufficient drying time, polish the surface to a finished shine. In general, aggressive cleaning agents should be avoided, as they can damage the wood or destroy the protective layer. It is also essential not to leave moisture on the surfaces for extended periods to prevent swelling or shrinking damage. Ultimately: clean regularly, maintain as needed based on condition – this will preserve the surface for many years.
NOAHSAU
18 Dec 2021 14:22
nonere schrieb:
For surfaces treated with oil wax, occasional refreshment using a colorless furniture wax is advisable.
An interesting point that I wouldn’t fully agree with. Especially with Ikea Hemnes furniture, which is heavily processed and often has only a thin layer of wax, I think applying furniture wax is overrated. This adds another layer to the wood that can attract dust and, over time, even cause unsightly discoloration. In my experience, regular cleaning with a slightly damp cloth and occasional care with natural wood oil is sufficient when the wood is oiled. Anything beyond that can, in the worst case, lead to an uneven surface that requires tedious refinishing. Sometimes less really is more. Surface care is often reduced to a single product because it sells better in marketing – but simple home remedies can sometimes be the best solution.
glaro
19 Dec 2021 08:05
NOAHSAU schrieb:
In my experience, regular cleaning with a lightly damp cloth and occasional treatment with natural wood oil is sufficient when the wood is oiled.
Thank you for this comment. I also tend to prefer as natural products as possible. However, the Hemnes usually comes lacquered as standard – do you think it would be advisable to remove the lacquer and oil the piece of furniture myself? Or is that not practical or too labor-intensive? I ask because I am interested in a natural surface, but at the same time, durability and protection are important. Is there even a way to remove the lacquer without damaging the wood? And if so, which oils would you specifically recommend? I want to avoid damaging or negatively altering the furniture through incorrect care.
nonere
19 Dec 2021 10:36
glaro schrieb:
Is there any way to remove the paint without damaging the wood?
In general, it is possible to remove the paint from Ikea Hemnes furniture, but it requires considerable effort and care. The paint is usually applied in a thin layer, so sanding can quickly damage the underlying wood. If you choose this method, I recommend using fine-grit sandpaper (grit ≥ 180) to avoid removing too much wood. Alternatively, chemical paint strippers are available, but they are not very environmentally friendly and can pose health risks.
Regarding oil: For Hemnes, a natural wood oil based on linseed oil or tung oil is a good choice, as these penetrate deeply into the pores and provide a protective, breathable finish. It is important to apply the oil thinly and to remove any excess after a few hours to prevent sticky spots. This usually enhances the appearance, making it look more “alive,” and effectively protects against moisture. However, keep in mind that an oiled surface is significantly more sensitive to stains than a painted one.
If you don’t mind the effort and maintenance, this can be a high-quality alternative; otherwise, regular care of the painted surface with mild cleaners is completely sufficient.
