ᐅ Which screws should I consider replacing in an Ikea Platsa system?
Created on: 31 Jan 2018 09:17
mico63
mico63
31 Jan 2018 09:17
Hello everyone, I recently assembled an Ikea Platsa shelving unit and I am unsure whether I should replace some of the screws included with stronger or different types. My goal is to improve the stability and especially the durability, as I plan to use the shelf for heavier items like books and electronics. Specifically, I am wondering which screws in the Platsa system—such as the base frame screws, the module connection screws, or the screws securing the back panel—should be replaced for safety and longevity reasons. Are there any experiences with alternative types or brands of screws? I am particularly interested in whether the thread or material of the screws used by Ikea is critical, and if it is advisable to switch to stainless steel or galvanized options. Can anyone share insights from personal experience or technical knowledge? Thanks in advance!
lochen
31 Jan 2018 09:45
Hello mico63,
basically, the screws provided by Ikea for the Platsa system are designed to match the construction and should be sufficient for normal loads. However, I understand your desire for extra security, especially if you are loading the shelf heavily.
My recommendation:
- The connecting screws between the modules are usually still solid, and you normally don’t need to replace these.
- The base frame screws, which stabilize the shelf, can be replaced with galvanized or stainless steel screws to prevent corrosion, particularly if the shelf is placed in a more humid room.
- The back panel fasteners bear less load, so the originals are usually sufficient here.
It is important that the screws have the same thread and length to avoid compromising structural integrity. Sometimes, screws that are too long can damage the material.
I hope this helps!
MATHIASDO
31 Jan 2018 10:11
Interesting approach, mico63. However, I would suggest that the issue should be considered in more detail. You seem to want to increase the "stability and durability," but this is not necessarily achieved simply by replacing the screws.
mico63 schrieb:
My goal is to increase stability and especially durability because I want to use the shelf for heavier items like books and electronics.
It would be important to check whether the actual material of the panels and the construction can meet your requirements. If the load is too high, the limiting factor is not the type of screw, but the load-bearing capacity of the furniture material.
It would also be worth considering whether you could tighten the screws instead of replacing them. Replacing screws might even void any warranty—some manufacturers can be quite strict about this.
Regarding screw materials: stainless steel is corrosion-resistant but is not necessarily stronger than other types of steel. Zinc-plated screws offer a good compromise. Do you already have specific screw types or sizes in mind? Only then can an appropriate recommendation be given.
Ryker66
31 Jan 2018 10:27
Short answer: Mainly replace the screws that stabilize the base frame. You can leave the connecting screws of the individual modules as they are. Screws in the back panel are less important. When replacing, always make sure to use the correct thread type and length.
risar
31 Jan 2018 11:04
Hello mico63,
I have a Platsa shelf myself, which I load with heavy boxes. So far, I haven’t replaced any screws but have focused on making sure all screws are tight and the shelf is level.
MATHIASDO schrieb:
It would also be interesting to know if you could simply tighten the screws instead of replacing them.
That’s a very good point. Loose screws are often the main cause of instability, especially with furniture.
To answer your question about replacing screws: if you decide to buy replacements, look for screws made of hardened steel, ideally with a self-tapping tip to make them easier to screw into the wood and provide better grip. Zinc-plated or stainless steel screws will protect against moisture if your setup requires it. To be honest, I haven’t seen a need to change the screws in the back panel system, as they bear very little load.
I hope this helps you.
mico63
1 Feb 2018 07:38
Thanks already for the many helpful suggestions!
I also wanted to explain in more detail that my main suspicion is that the existing screw fastenings lose stability over time due to material fatigue and slight movements in the sleeves within the chipboard – that’s what I meant by "durability." That’s why I was thinking of using harder screws or, for example, screws with a larger diameter in the same drill holes to achieve better grip.
That’s exactly my concern too, that different screws might actually damage the furniture.
MATHIASDO schrieb:
Replacement could also mean losing warranty claims – Ikea can be quite strict about this.
Warranty is not very important to me since I’ve had the shelf for a long time now.
Have any of you had experience with other types of screws you would recommend? And do you have any tips regarding the size of alternative screws? For example, replacements with wood screws that have a different head shape? Thanks!
