ᐅ Which screws should I consider replacing in an Ikea Platsa system?
Created on: 31 Jan 2018 09:17
mico63
Hello everyone, I recently assembled an Ikea Platsa shelving unit and I am unsure whether I should replace some of the screws included with stronger or different types. My goal is to improve the stability and especially the durability, as I plan to use the shelf for heavier items like books and electronics. Specifically, I am wondering which screws in the Platsa system—such as the base frame screws, the module connection screws, or the screws securing the back panel—should be replaced for safety and longevity reasons. Are there any experiences with alternative types or brands of screws? I am particularly interested in whether the thread or material of the screws used by Ikea is critical, and if it is advisable to switch to stainless steel or galvanized options. Can anyone share insights from personal experience or technical knowledge? Thanks in advance!
To provide a more detailed explanation regarding screw replacements for Ikea Platsa:
The original Platsa system mainly uses metric cylinder head screws and connector screws with a round head and internal hex drive. These are selected to fit precisely with the metal connectors (sleeves).
If you choose screws with a larger diameter or a different profile, this can cause the sleeves to split or damage the particleboard material. This would actually reduce the overall stability.
Recommended guidelines are:
- When buying replacement screws, try to match the diameter, length, and thread pitch as closely as possible.
- Stainless steel or galvanized versions can offer corrosion protection but are usually mechanically similar.
- For the connector screws of the modules, it is better to use original types or comparable special screws with a hex drive.
If you want to increase stability, I would suggest adding extra braces or angle brackets to provide additional support to the shelving unit.
This will help prevent the entire load from relying solely on the screws and avoid placing too much stress on the wood.
If you want to replace screws, definitely use full-thread screws, not partial-thread. Also, use heat-treated ones for better durability.
Length and diameter should match the original to ensure the holes fit. For the base frame, use stainless steel or galvanized screws. For the internal modules, standard screws are sufficient.
In summary, regarding the technical aspect: with Ikea Platsa, the weak point is usually not the screw itself, but the connections between the particleboard and the metal insert.
This assessment is correct. Therefore, I recommend, if possible, regularly tightening the screws and, if needed, reinforcing the hollow spaces in the connection points with wood glue or special reinforcements.
Replacing the screws with larger or harder screws is often counterproductive because they can damage the sleeve insert. It is better to keep the original dimensions.
Additionally, metal brackets or cross braces help to significantly improve the overall stability.
mico63 schrieb:
I also wanted to explain in more detail that I mainly suspect the existing screw fastening loses stability over time due to material fatigue and slight movements of the inserts in the chipboard
