ᐅ Which protective coatings are best suited for IKEA Besta furniture?
Created on: 8 Jun 2020 09:14
gifeba
I plan to apply a protective lacquer to my IKEA Besta furniture to make the surface more resistant to scratches, liquids, and general wear. Since the Besta furniture is made of laminated wood-based material, I am wondering which types of protective lacquers are best suited for this, without dissolving the surface or causing unattractive changes.
My requirements are:
- UV protection to prevent color fading
- Scratch resistance
- Easy cleaning
Does anyone have experience with a specific type of lacquer (e.g., acrylic lacquer, polyurethane lacquer, water-based) or know of any brands that have worked particularly well? Also, what about the application process—are there any tips to ensure good adhesion and an even finish?
Thanks in advance for your tips and recommendations!
barle
8 Jun 2020 14:17
For IKEA Besta furniture, I recommend water-based acrylic paints.
They hardly alter the surface of the laminate and provide good protection.
Proper preparation and applying thin layers are essential.
jordanvin
8 Jun 2020 15:38
Hey everyone, I can't hold back: painting is such a great DIY project!
My recommendation: water-based polyurethane (PU) varnishes! They are durable, have a great gloss finish, and don’t have a long-lasting smell.
Of course, you need to pay attention to drying times occasionally, but if you do, you’ll enjoy your work for a long time!
Don’t stress, just give it a try! 👍🔥
boelnu
8 Jun 2020 16:05
jordanvin schrieb:
My recommendation: water-based PU varnishes! They are durable, have a great gloss, and don’t smell for ages.
Thanks for sharing your experience! After reading your report, I was wondering how these PU varnishes compare to acrylic paints in terms of long-term use. Does the surface film really adhere that well to PU varnishes?
I also have concerns about strong odors or possible plasticizers that might alter the surface over time.
Ethan
8 Jun 2020 16:42
boelnu schrieb:
I was wondering after reading the report how PU coatings compare to acrylic paints in long-term use. Does the foil really adhere well to PU coatings?
That is a valid question. PU coatings are generally more durable and long-lasting than standard acrylic paints. However, PU coatings often contain solvents that can partially dissolve the foil laminate on Besta furniture.
Therefore, caution is advised: if you want to use PU coatings, it is essential to choose products specifically designed for plastic or foil surfaces—and to test them first on an inconspicuous spot.
For most DIY users, water-based acrylic paints are the safer choice, as they tend to cause significantly fewer issues with adhesion and surface quality.
PRA64
9 Jun 2020 09:18
A brief addition to the tips: If you prefer a paint with a matte finish, make sure the paint is not only matte but also suitable for application on foil.
Some matte paints can become porous or brittle when applied to foil coatings.
When applying, it is essential to use a good brush or, even better, a spray gun to avoid brush marks.
If you don’t have a spray gun, foam brushes are often a better alternative to bristle brushes, as they help achieve a streak-free surface.
Kinbu
9 Jun 2020 11:07
One more tip: It is best to first protect the Besta surfaces with a thin layer of special primer for plastic or film before applying the topcoat.
This significantly improves adhesion and prevents later peeling or flaking.
