ᐅ Which protective coatings are best suited for IKEA Besta furniture?
Created on: 8 Jun 2020 09:14
gifeba
I plan to apply a protective lacquer to my IKEA Besta furniture to make the surface more resistant to scratches, liquids, and general wear. Since the Besta furniture is made of laminated wood-based material, I am wondering which types of protective lacquers are best suited for this, without dissolving the surface or causing unattractive changes.
My requirements are:
- UV protection to prevent color fading
- Scratch resistance
- Easy cleaning
Does anyone have experience with a specific type of lacquer (e.g., acrylic lacquer, polyurethane lacquer, water-based) or know of any brands that have worked particularly well? Also, what about the application process—are there any tips to ensure good adhesion and an even finish?
Thanks in advance for your tips and recommendations!
- Easy cleaning
Kinbu schrieb:
The best way to protect Besta surfaces is to start with a thin layer of special primer designed for plastic or laminateThat’s absolutely right! I did exactly that before applying the paint. The adhesion is excellent, and my furniture still looks great after one year!
Don’t be discouraged, it’s really enjoyable, and in the end, you’ll get fantastic results!
Thanks to everyone for the valuable input so far! However, I would like to revisit the question of whether anyone has tips on which products are particularly suitable as primer and paint for Besta. I found some paints at the hardware store, but they often only say "for wood" or "for plastic" without any detailed information.
Are there any well-known brands or product lines that you have successfully used or would recommend in this context?
I would appreciate it if you could share your favorites.
Here are some recommendations for selecting products:
- Primer: A "special primer for plastic and films" is often labeled as an "adhesion primer" or "bonding agent." Brands such as Sikkens or Clou offer these products.
- Paint: Water-based acrylic paints from manufacturers like Clou, Remmers, or Sikkens are suitable for film coatings and have positive user reviews.
As a general rule: Always read the product datasheet beforehand to confirm if it is suitable for use on plastic or film-coated surfaces.
And as always: test on a small, inconspicuous area first!
