Hello everyone, I am planning to buy a Pax wardrobe from Ikea that should be especially sturdy and durable. My question is: Which Ikea Pax wardrobes are particularly robust when used intensively every day, for example for heavy clothing or occasionally storing bulky items? I am especially interested in the quality of the materials, the stability of the wardrobe structure, and whether certain designs or combinations (e.g., framed doors, sliding doors, or specific interior fittings) are better in terms of longevity than others. I want to avoid the wardrobe becoming wobbly or having doors that warp after a short time. Thanks for your experiences and recommendations!
Nicholas47 schrieb:
I wonder if the standard PAX depth of 60cm (24 inches) provides enough stability, or if I should rather choose the 35cm (14 inches) version, which is often described as more stable? This is an important question that shouldn’t go without a comment. The common claim that the 35cm (14 inches) version is more robust is often based on subjective impressions. In fact, stability depends more on correct installation and reinforcement than on the depth itself. The 60cm (24 inches) depth offers more design flexibility for different uses, but greater depth also means higher stress on shelves due to longer leverage. Without proper reinforcement, deformation can indeed occur more quickly. Another crucial factor is the materials used, especially whether the shelves or bottoms are reinforced with additional elements. General statements are not very helpful here, as usage conditions can vary widely.
Here is a more structured overview of the durability of Pax wardrobe models, which may help you with your decision:
1. Material and Construction – Standard Pax carcasses are made from melamine-coated particle boards, which are sufficiently stable under normal loads.
– Frame doors with pine wood frames are more durable and less prone to warping than full-panel doors.
2. Depth – A depth of 60 cm (24 inches) offers more space, but the shelves are more heavily loaded, which can lead to sagging without reinforcement.
– A depth of 35 cm (14 inches) is inherently more stable because the load paths are shorter and the shelves are less stressed.
3. Reinforcements – Metal brackets under heavy shelves are especially important.
– The sturdiest models have recessed or metal shelves, which are particularly load-bearing.
4. Doors – Sliding doors are more sensitive to load and require precise adjustment.
– Frame doors are easier to maintain and more durable.
5. Interior Layout – For heavy shoes or bags, use shelves with metal reinforcement.
Summary:
If you plan for heavy loads and intensive use, I recommend:
– Frame models with pine wood doors
– Standard 60 cm (24 inches) depth only with additional reinforcement
– Shelves with metal reinforcement or at least reinforced brackets
– Careful installation with proper alignment and secure wall anchoring
This will help you handle higher loads well and enjoy your wardrobe for a long time.
Summary:
Linavin schrieb:
The common claim that the 35cm (14 inches) version is more robust is often based on subjective impressions. I agree with that. However, the usage criteria should be defined very precisely. With heavy use and loads, the longer leverage effect at 60 cm (24 inches) depth becomes noticeable, especially if no additional reinforcements are installed.
Enrico4 schrieb:
Cabinets with frame doors are mechanically more stable and less prone to warping. This matches my experience. The pine wood frames keep the doors stable even when humidity levels change.
I recommend choosing models with pine frame doors combined with metal reinforcements and ideally metal shelves for the planned application. Also, pay attention to wall anchoring to prevent the entire cabinet from tipping or wobbling.
