ᐅ Which Ikea Pax shelving systems are designed to support heavy loads?
Created on: 24 Apr 2021 08:13
Lamiso
Hello everyone, I am currently planning a new cabinet system for my home office and am specifically interested in the IKEA Pax series. Since I need to store some very heavy binders, technical equipment, and various tools, the load capacity of the shelving systems is particularly important to me.
My specific question is:
Which models or variants of the IKEA Pax system are designed to support especially heavy loads? Are there differences in materials, construction, or recommended weight limits?
I would also appreciate any experiences regarding stability under full load or tips on how to best reinforce the modules to ensure they remain secure even with heavy weight.
Thank you in advance for your advice and suggestions!
PECLARISSA24 Apr 2021 19:03I’m happy to join in, but with a bit of encouragement!
Of course, the PAX system can’t support elephants – anyone expecting that is mistaken. But with some creativity and planning, it can definitely hold quite a lot.
For example, I installed additional metal brackets and sturdy shelves myself. Combined with wall mounting, it has held up really well so far, even with quite heavy items like large boxes of books and electronics.
It’s important not to overload a single compartment all at once, but to distribute the weight evenly. The PAX modules are designed to be modular, and that’s exactly what they’re made for.
So, Lamiso: with care and the right extras, you can get a stable system that supports your heavy items well – at least within the limits of the design.
Where exactly are you planning to put the wardrobe? Is it close to a wall or an exterior wall, where you might be able to improve the fixings?
bapar schrieb:
How heavy are the individual items you want to store? Maybe that way it would be easier to suggest a more targeted solution.Thanks for the tips, especially regarding weight distribution and wall mounting. The individual items usually weigh between 8 and 15 kg (18 and 33 lbs), and I plan to store more than 5 binders per shelf. In addition, there are some technical devices weighing around 10 to 20 kg (22 to 44 lbs) – mostly smaller printers and scanners.
Layla schrieb:
For me, it was important to enhance the system with a variety of stabilization options, meaning: additional wall mounts, connecting the individual modules with the supplied screws and reinforcements, and proper weight distribution.That already sounds like a good approach. Are the metal brackets and extra reinforcements easy to install, or do they require special tools? I also want the option to expand the modules later on if needed.
Thanks to everyone for the helpful advice – I’m looking forward to more detailed suggestions!
Lamiso schrieb:
Are the metal brackets and additional reinforcements easy to install, or do you need special tools?Good morning, Lamiso,
installing reinforcements like metal brackets is usually straightforward if you have some basic DIY skills and a good cordless drill. Mostly, you just need screwdrivers or a cordless drill, suitable screws, and anchors (especially for wall mounting).
It’s important to attach the brackets to load-bearing parts, preferably the structural frame, rather than just the shelves themselves.
Many reinforcement parts are standardized, and IKEA also sells compatible accessories, but you can find suitable brackets at hardware stores if you want a more robust setup.
Make sure to follow the instructions precisely when fixing to the wall to avoid any risk of tipping. It’s also wise to check whether the wall can support the weight, depending on the wall material.
For future expansions, you can proceed the same way by attaching new modules to the existing ones and adding extra reinforcements.
If you like, I can also share specific tips on the best screws and brackets depending on the material.
