ᐅ How can you customize the interior of a Pax wardrobe yourself?
Created on: 5 Aug 2020 09:12
lafebarHello everyone,
I am currently planning to customize the interior of my IKEA Pax wardrobe myself to make the most of the storage space and create a solution tailored to my needs. I am particularly interested in the options available for designing the interior without being limited to the pre-made IKEA inserts.
Specifically, it would be helpful to know how to arrange shelves, drawers, or clothes rails flexibly, whether it is possible to build additional components yourself, and which materials are suitable for this. What about stability and mounting?
Are there any proven tips or experiences on how to customize the interior of a Pax wardrobe without it becoming unstable or impractical in the end? I look forward to your detailed suggestions and experiences!
You can adjust the shelves and clothing rods at the designated holes in the frame flexibly. For custom solutions, I recommend using sturdy wooden panels or metal brackets. Secure these well with screws on the sides. Make sure to observe the maximum load capacity of the Pax.
Good morning,
this topic offers more possibilities than it might seem at first glance. Basically, the Pax system is designed to be modular, meaning all shelves and drawers can be adjusted and replaced quite easily. To customize the interior yourself, I recommend the following steps:
- Planning: Draw a floor plan of your wardrobe interior in advance with the desired measurements. This way, you will know exactly how much space you have for different elements.
- Choice of materials: Instead of the original IKEA shelves, you can opt for plywood or MDF boards with an appropriate thickness (at least 18 mm (0.7 inches)). These boards are easy to cut and laminate.
- Fastening: Use sturdy brackets, such as zinc-coated heavy-duty angle brackets, to secure the shelves. The Pax side panels have holes at fixed intervals, where you can either drill yourself or use toggle bolts.
- Drawers and baskets: If you want to build your own drawers, be sure to use suitable guide rails (telescopic slides). An alternative is baskets or boxes placed on shelves.
- Clothes rails: You can either use the original rails or, if you have other ideas, install sturdy metal pipes or battens at the correct distance. However, the load-bearing capacity should not be underestimated.
I would like to know how much experience you have with DIY projects and what tools you have available. This is important to accurately assess the level of difficulty.
FAZAR schrieb:
I would like to know how much experience you have with DIY projects and which tools you have available. This is important to properly assess the level of difficulty.Good question, thanks! I have solid basic skills in DIY, and I own a jigsaw, cordless screwdriver, drill, and sandpaper. I am familiar with precise work and planning, but I have never cut or modified furniture parts myself. Therefore, it would be helpful if recommendations provide step-by-step guidance and highlight potential pitfalls. Stability and strong fastenings are important to me, and I want to be sure that I am not working with material that is too thin.
Alberto515 Aug 2020 15:21I really appreciate how carefully you formulated your request! I felt the same way back then – I wanted to design the interior myself and wasn’t sure if I was doing everything correctly. I had particular difficulty choosing the right material. Here are my tips:
- Choose slightly thicker panels; they can support more weight.
- When installing the floors, I initially felt relieved about the corner brackets because they provide a more secure feeling.
- When cutting, definitely use a guide rail for your jigsaw to ensure everything is precise – it makes the process much easier.
I also arranged the closet rods a bit differently and was initially unsure if they would hold the load. But in my experience, everything stays firmly in place when you use screws with good grip.
I made some small mistakes during planning, but in the end, I really loved my setup. Patient trial and error can sometimes feel like a bit of a test, but it’s definitely worth it.
Alberto51 schrieb:
I really appreciate how carefully you formulated your request!I agree with that. Thorough planning is essential; otherwise, things just become chaotic. Regarding materials: use MDF or plywood, always straight and not warped – otherwise, you will encounter problems during installation later.
