ᐅ Which Ikea Pax drawers offer the most storage space?
Created on: 24 Sep 2020 11:13
bau41
bau41
24 Sep 2020 11:13
I am currently planning to expand my wardrobe using Ikea Pax and am particularly looking into the different drawer options. My main question is: Which Ikea Pax drawers are especially spacious and best suited for storing larger clothing items like sweaters, jeans, or even shoes?
It is also important to know if there are differences in drawer depth, and whether some models offer significantly more capacity than the standard versions. Additionally, I am interested in practical experiences regarding how sturdy the larger drawers are, especially when fully loaded.
I would really appreciate a structured overview of the available Pax drawer models along with recommendations, so I don’t end up buying too many unnecessary parts. Thanks in advance!
stefangla
24 Sep 2020 17:29
Hello bau41,
regarding your question about which Pax drawer is particularly spacious, I can give you a brief overview:
- The Pax drawers with a width of 100 cm (39 inches) and a depth of 58 cm (23 inches) are definitely the largest that Ikea offers. These naturally provide a lot of storage space.
- Within these dimensions, there are versions with full extension and soft-close features, which also affect usability.
- Heights usually vary between 10 cm, 20 cm, and 40 cm (4, 8, and 16 inches), with the 40 cm (16 inches) drawers being better suited for larger items like sweaters or jeans.
A common mistake in planning is to judge drawers only by width and height, although the correct internal height and depth are crucial. Therefore, be sure to pay close attention to the internal dimensions listed in the product description.
Regarding stability, I can say that Ikea’s black metal runners are very durable, but you should not exceed the specified maximum load – for the 100 cm (39 inches) wide drawers, this is usually around 25 kg (55 lbs) per drawer.
In short: for maximum space utilization, choose drawers with a large height (about 40 cm / 16 inches) in the 100 cm (39 inches) wide Pax frame depth. Alternatively, deeper drawers (e.g., 58 cm / 23 inches) are better than shallower ones.
If you like, I can also give you tips for optimal internal setup with dividers or drawer organizers.
mifra
25 Sep 2020 08:44
stefangla schrieb:
- The Pax drawers with a width of 100 cm (39 inches) and a depth of 58 cm (23 inches) are definitely the largest offered by Ikea. They naturally provide a lot of storage space.
I fully agree with that. Additionally, it’s important to distinguish that Ikea Pax units with a depth of 35 cm (14 inches) have different drawer modules than those with 58 cm (23 inches) depth. The 58 cm (23 inches) deep models are clearly recommended for spacious drawers.
The standard heights are 10 cm (4 inches), 20 cm (8 inches), and 40 cm (16 inches). For larger clothing items, 40 cm (16 inches) is recommended, while 10 cm (4 inches) is sufficient for small accessories.
The maximum load capacity for the drawers is stated by Ikea to be around 25 to 30 kg (55 to 66 lbs), provided the metal runners are properly installed and undamaged.
Very important: You should check the internal dimensions directly on Ikea’s website or in the catalog, as the front measurements often don’t match the usable interior volume.
Conclusion: For your project, large Pax drawers with 100 cm (39 inches) width, 58 cm (23 inches) depth, and 40 cm (16 inches) height are ideal. This way, you can easily store jeans, sweaters, and even shoes.
Ryker66
25 Sep 2020 10:03
The largest Pax drawers are the 100cm (40 inches) wide ones combined with a depth of 58cm (23 inches) and a height of 40cm (16 inches). These offer the most storage space.
If you need room for thick sweaters or several pairs of shoes, be sure to choose these.
TYRELL
26 Sep 2020 14:22
I would like to add that when choosing the most spacious drawer, it’s not only about the external dimensions but also the internal measurements of the drawer. Ikea Pax drawers have fixed side panels, and the available storage space is somewhat reduced by these internal walls and the thickness of the carcass.
For 100 cm (39 inch) wide drawers with a depth of 58 cm (23 inch), you should roughly expect the following internal dimensions:
- Internal width: approx. 90 cm (35 inch)
- Internal depth: approx. 50–53 cm (20–21 inch)
- Internal height: depending on the variant, about 36–38 cm (14–15 inch) with a 40 cm (16 inch) high front panel
Additionally, the stability is largely influenced by the drawer runners, which Ikea officially rates to hold up to 25 kg (55 lbs) per drawer. Correct installation using the provided screws is important to ensure optimal load distribution.
If you plan to store heavier items, doubling the drawers by adding extra dividers could also be useful to distribute the weight.
A somewhat underrated feature is the full-extension function. Especially for large drawers, it’s worth investing in full-extension drawers so that you can easily access items even at the very back, making the usage truly convenient.
Finally, it would be helpful if you could specify the exact depth of your Pax carcass and whether you intend to use drawers in a standard 50 cm (20 inch) deep or 58 cm (23 inch) deep carcass. The depth of the carcass is a key factor in selecting the appropriate drawers.
If you like, I’m happy to assist you with calculating the internal volume or finding the right combination of drawer heights for different types of clothing.
