ᐅ Which Ikea Pax doors are particularly suitable for people with allergies?
Created on: 7 Oct 2022 09:23
Bidemian
Bidemian
7 Oct 2022 09:23
I am currently deciding on which doors to choose for my new Ikea Pax wardrobe that are especially suitable for allergy sufferers. Since I suffer from allergies myself and need to consistently use low-emission and allergen-reducing materials in my household, I am interested in which Pax door models are best suited in this regard.
It is important to me that the doors at least meet the following criteria:
- as low-emission as possible or free of volatile organic compounds (VOC)
- odor-neutral or at least emit very little odor
- easy to maintain, so that dust and allergens do not easily stick
- preferably do not contain materials that promote mold growth
Has anyone had experience with the different Pax doors, such as sliding doors in glass or wood finish, folding doors, or full door models? Which materials or finishes are particularly recommended for allergy sufferers, and are there any indications from Ikea itself regarding low-emission options?
Thank you in advance for your detailed assessments and shared experiences!
Gafiel
7 Oct 2022 13:47
Hello Bidemian,
Your question about Ikea Pax doors suitable for allergy sufferers touches on an important aspect that is often underestimated: material compatibility and indoor air quality.
First of all, it is important that the doors are made from materials that emit little to no formaldehyde or other volatile organic compounds (VOCs). Ikea generally uses medium-density fiberboard (MDF) with surface coatings for Pax doors. The standard paints or laminates on the doors can release small amounts of emissions, although Ikea states that they ensure these values remain below the regulated limits.
- Glass fronts (especially tempered safety glass) usually perform better in this regard, as glass is emission-free and easier to clean, which is beneficial for allergy sufferers. However, it is important to make sure that the frame construction made of wood or MDF is also low-emission.
- For solid doors, surfaces such as laminate, melamine, or paint are common depending on the model. Melamine-coated surfaces are relatively unproblematic, as they are washable and do not release fibers.
- Folding doors often consist of MDF with various surface finishes; here, the risk of dust accumulation is somewhat higher, especially in the folding mechanisms, which can be a disadvantage for allergy sufferers.
Another important consideration is the precise fitting to avoid gaps where dust or mold can accumulate. Doors with smooth surfaces and minimal joints offer advantages in this regard.
In conclusion, I would recommend specifically asking Ikea for the current emission and health certificates for Pax doors or checking the product information. If possible, also test the smell directly in the store—a very strong chemical smell is a warning sign.
One more question: are you planning to use the doors in a particularly humid room or rather in a bedroom? This could slightly influence the choice.
Nakar33
7 Oct 2022 16:53
Gafiel schrieb:
First of all, it is important that the doors are made of materials that emit little to no formaldehyde or other volatile organic compounds (VOCs).
That is absolutely correct and crucial for allergy sufferers. I would like to add that besides emissions, the surface texture also plays a key role. Smooth surfaces are easier to clean and prevent the buildup of dust and mites, which is a great help for allergies.
- For Ikea Pax doors, options with lacquer or foil coatings are especially recommended, as they do not have porous surfaces.
- Glass fronts are ideal, but in this case, the frame material should also have low emissions.
Gafiel schrieb:
Another important consideration is the precise fit and avoiding gaps where dust or mold can accumulate.
I fully agree. Dust tends to collect in the joints of folding doors. Additionally, they are more prone to mechanical wear, which can also lead to dust traps over time.
You should also pay attention to indoor humidity: High humidity increases the risk of mold, especially if the door materials absorb moisture (such as wood or low-quality MDF).
My recommendation:
- Solid doors with foil coating or lacquer; good examples are the PAX doors "Damask" or "Kassett" (depending on availability) with smooth surfaces
- Sliding doors with tempered safety glass fronts and aluminum frames
Have you already tested how the different doors work in your actual space (lighting, ease of use)? This can also make a difference, especially if you frequently open and close doors to minimize allergen circulation.
neoren
8 Oct 2022 08:09
For allergy sufferers, doors with smooth, solid surfaces are especially suitable, preferably painted or laminated.
Avoid fabric or wood grain patterns to prevent dust accumulation.
Glass sliding doors are excellent if they have minimal framing.
Folding doors are less recommended due to the gaps.
daalessio
9 Oct 2022 10:32
Bidemian schrieb:
Has anyone had experience with the different pax doors, such as sliding doors in glass or wood finish, folding doors, or full-door models? Which materials or finishes are particularly recommended for allergy sufferers, and does Ikea provide any information about low-emission options?
In response to your question, here is a summary:
- Glass fronts are highly recommended due to their tightness, ease of cleaning, and being emission-free.
- Painted or melamine-coated full doors also perform well, as they offer smooth surfaces and low emissions.
- Fabric-covered or folding doors are less suitable and can attract dust.
Ikea provides environmental and emission certifications (e.g., E1 standard for wood-based panels) for some models, but unfortunately, not all doors explicitly display this information. It is definitely worth asking at the store.
If you want to be absolutely certain, ventilation is also very important since even low-emission furniture can affect indoor air quality.
I hope this helps!
