ᐅ Which Ikea Pax doors are best suited for customization?
Created on: 6 Sep 2016 19:27
kabaman
kabaman
6 Sep 2016 19:27
I am currently planning to upgrade my Ikea Pax system, and the doors are a key focus for me. Specifically, I’m wondering which Ikea Pax doors are best suited for customization, whether through painting, applying decals, covering with film, or other DIY methods. I’m especially interested in which doors are mechanically and materially the easiest to modify over time or to experiment with different finishes.
It would also be important to know if there are doors with smooth surfaces or specific material properties that make them better for painting or applying decals compared to others. There are some online tips available, but the advice is often quite mixed.
Who has experience with the different Pax door models and can share practical insights on which doors are best for customization without compromising appearance or functionality? I’m looking forward to your recommendations and tips!
SETHBLA
6 Sep 2016 21:42
I would recommend smooth, painted doors. They have a surface that is relatively easy to paint and apply stickers to, and the paint on them is more durable. Doors with mirrors or glass are naturally more difficult to work on; in those cases, it’s better to use films rather than paint directly.
benonon
7 Sep 2016 07:38
Hello kabaman,
your question is very well put and relates to an aspect that is often underestimated. Choosing the right Pax door for individual customization mainly depends on the surface texture and stability.
Currently, Ikea offers several types of Pax doors, such as:
- Smooth, painted doors (often laminated but with a smooth surface)
- Mirror doors
- Glass doors (clear or frosted)
- Folding doors
- Sliding doors
For individual customization, the smooth, painted doors—especially those from the "Vikedal" or "Hundvåg" series—are highly recommended because they provide a consistent, stable surface that can be sanded, primed, and treated with various techniques. This is particularly important if you plan to work with acrylic paints or special films.
Be careful with doors that have a laminated surface: the laminate often does not provide good adhesion for paint because it is usually smooth and somewhat tear-resistant, which inevitably leads to peeling later on. Thorough preparation or completely removing the laminate is necessary, though the latter can be labor-intensive.
Mirror doors are difficult to work on because the surface is not painted and can be easily damaged mechanically. However, they can be effectively customized using special adhesive films or vinyls if done very precisely.
Folding and sliding doors are also not the best choice for extensive individual customization, as they are often made from flexible materials or plastics that can warp.
If you want to approach this very professionally, I recommend testing on a small area first and possibly applying a thin primer to ensure lasting adhesion.
I’m also curious: are you planning a permanent redesign or rather changing designs over time?
Penau
7 Sep 2016 11:04
benonon schrieb:
For custom designs, the smooth, painted doors—especially those from the "Vikedal" or "Hundvåg" series—are highly recommended because they provide a consistent, durable surface that can be easily sanded, primed, and treated with various techniques.
I can confirm this assessment. It’s worth carefully inspecting the surfaces at Ikea, as even slight differences between smooth doors and those with foil coverings can significantly affect the long-term durability of your finish.
Furthermore, I recommend considering the door type when choosing doors: if you want flexibility, standard overlay doors are better than folding doors. They are easier to remove and replace, which makes later customization simpler.
Another important feature: painted surfaces on doors will wear over time but are often easier to touch up than doors with foil or paper coverings.
In summary: smooth, painted doors from the Pax series are clearly the best choice for individual customization, especially when it comes to painting or applying vinyl wraps.
