ᐅ What are common assembly mistakes with the Ikea Metod kitchen system, and how can I avoid them?
Created on: 14 Jun 2018 18:07
Tine61
Tine61
14 Jun 2018 18:07
Hello everyone, I am currently planning the installation of my new Ikea Metod kitchen and have some concerns, especially regarding common assembly mistakes. My specific question is: based on your experience with Ikea Metod furniture, what assembly errors occur most frequently, and what advice do you have to specifically avoid these mistakes? I am interested not only in what can go wrong during assembly but also in how to prevent typical issues with alignment, stability, or the installation of cabinets and fronts from the start. Thank you very much for your expertise!
Romin
14 Jun 2018 18:52
Hi Tine61, great question! Having assembled several Metod kitchens myself, I can say one of the most common mistakes is not aligning the cabinets precisely side by side. This often causes the doors to not close properly or creates gaps. The key is to regularly check with a spirit level after each step! Also, be sure to attach the back panels carefully – they provide stability and prevent everything from wobbling. And don’t worry, even if it seems complicated, with patience and proper preparation, you’ll manage it – you’ve got this! 😊
lisbi
14 Jun 2018 19:35
Hello everyone, to clarify the discussion about common mistakes: besides the mentioned imbalance between the individual cabinet units, screws are often either overtightened or too loose. Both can cause long-term issues. It is advisable to tighten screws gradually, meaning first secure all screws lightly and only fully tighten them at the end. Another point concerns the installation of dishwasher fronts – the adjustment options are limited, and misalignment can lead to crooked side panels. It is important to strictly follow the installation measurements according to the manual and to level the feet before attaching the fronts.
dunitan
15 Jun 2018 07:24
Hello Tine61 and everyone else, I would like to add to the topic. It is especially important, when assembling Ikea Metod kitchens, to start with good preparation: sort the individual parts and, above all, check the drilling holes. I often notice confusion with the right and left side panels because the parts often look very similar. Referring to the assembly instructions before each step helps a lot to prevent incorrect installation. Additionally, I would recommend assembling on a level surface – unevenness on the floor can cause doors not to close properly later or make the entire structure feel unstable.
kulau
15 Jun 2018 11:46
Hello everyone, I’m taking the time to break down the most common mistakes in detail and provide solutions for each:
- Incorrect sequence of assembly steps: This often leads to screws not fitting properly or being difficult to reach. Always follow the order in the instructions carefully, as, for example, mounting the front panels before securing the countertop can cause problems.
- Ignoring angles: A Metod kitchen requires precise right angles to keep gaps between cabinets to a minimum. Fine adjustments can be made using a large spirit level and a pry bar.
- Confusing components: Side panels and shelves may look similar but are often asymmetrical. Mistakes here will cause hinges not to fit correctly later on.
- Neglecting the back panel: The back panel is usually attached with only small nails or screws but plays a crucial role in stability and prevents lateral tipping.
- Over-tightening or stripping screws: This can damage holes and weaken the connection. Therefore, work carefully and limit the torque when using power tools.
I’m interested in which steps you are currently working on so I can provide more targeted advice.
kegachen
15 Jun 2018 14:08
In short: Glass or glass doors are often installed incorrectly – pay attention to the door stops! Always align all cabinets at floor level first, then assemble them. Do not fully tighten screws immediately; start by screwing them in loosely. Always secure the back panels completely, as this greatly stabilizes the structure.
