ᐅ Which cable glands are suitable for pax units with lighting?
Created on: 21 Mar 2015 18:27
parnau
parnau
21 Mar 2015 18:27
Hello everyone, I am planning to equip my Pax wardrobe with integrated lighting. I have a question regarding which cable grommets or feedthroughs work best to guide the cables neatly, safely, and in an aesthetically pleasing way through the wardrobe panels without affecting the lighting. It is important to me that the cable feedthrough is sturdy, has no sharp edges, and ideally provides some protection against dust or dirt. Perhaps you have experience with specific grommets, rubber sleeves, or other solutions that are well suited to the dimensions and materials of Pax wardrobes? I look forward to your recommendations and advice, including tips on installation or preventing cable damage.
SINTAR
21 Mar 2015 19:03
I would definitely recommend rubber grommets, as they are flexible and protect the cables. Standard sizes often fit well into the pre-drilled holes in the Pax units. Just make sure the grommet fits tightly, otherwise dust can enter the cabinet.
Morgan
21 Mar 2015 20:15
Thank you for the question, parnau, this is really important, especially when you put effort into the lighting—it should last well and look good. At the beginning, I was also worried that the cables might get damaged because I didn’t have the right materials. In the end, I used small plastic cable glands, which you can drill into the wall, and they have a type of rubber ring. This keeps the cables firmly in place and nothing is visible outside. However, I had to pay close attention to the cable diameter to ensure a good fit, which was a bit frustrating for me. My advice is to measure carefully one more time and then order the right size. This way, you can avoid unnecessary hassle.
Guyju
22 Mar 2015 07:58
Hello parnau, for my Pax with lighting, I have used a combination of the following cable grommets, which have proven effective:
- Flexible silicone cable grommets: They protect the cables and prevent sharp edges at the penetration point.
- Plastic cable glands with seals: These provide good dust protection and securely hold the cables in the opening.
A tip for installation:
1. Always drill the hole slightly larger than the cable to allow enough space for the grommet.
2. Carefully deburr the edges to avoid damaging the cable insulation.
3. For lighting cables, especially flexible LED cables, use a grommet made of soft rubber.
If you are connecting wired devices, it is also advisable to ensure the grommet is not too tight, allowing room for cable ends to move and preventing cable breakage.
Summary: Rubber and silicone grommets are usually the best choice for Pax, especially with integrated lighting. Plastic grommets with seals increase durability and provide dust protection.
TUELBA
22 Mar 2015 22:11
I would like to provide a more detailed explanation regarding cable entries in PAX units with lighting. Parneu, to give you the best possible advice, it would be helpful to know:
- What type of lighting is planned (LED strips, fixed lights, etc.)?
- How thick or large are the cables that need to pass through the panel?
- Are there already pre-made holes, or do you intend to drill them yourself?
In general, for installations in furniture like PAX, which is often made from wood or particleboard, cable entries with soft rubber grommets are recommended. These not only prevent cable damage from sharp edges but also reduce noise caused by cable movement.
Some technical details and tips:
- If you are drilling holes yourself, use a hole saw with a diameter slightly larger than the thickest part of the cable.
- The entry should not be too tight, since LED cables often have thinner sections near the connectors that could otherwise get pinched.
- Additionally, silicone sealing rings can be applied to keep out dust and minor moisture, which makes sense for lighting installed inside furniture.
For a secure fit, a small mounting aid or adhesive designed for assembly can be used to fix the grommet without damaging the material of the PAX unit.
What are your specific requirements? Then I can provide you with more tailored advice.
