ᐅ What installation tips can make assembling Ikea Metod kitchens easier in rental apartments?
Created on: 12 Apr 2016 14:37
Sethken
Sethken
12 Apr 2016 14:37
Hello everyone, I’m currently installing the Ikea Metod kitchen in my rental apartment and encountering some typical issues that are especially relevant in a rental setting. I’m wondering which installation tips you know and can recommend that make fitting kitchens in rental properties easier—such as gentle fixing methods, wall types, alternative fastenings, or protecting the rental property. Are there any tricks to ensure stability without causing permanent damage to the walls? Or do you have recommendations for tools and materials that simplify the assembly? I look forward to your experiences and advice—also about challenges related to landlord restrictions on drilling or particular room situations. Thanks in advance!
relupa
12 Apr 2016 15:02
I can completely understand that installing a Metod kitchen in a rental apartment can be a real challenge, especially since you want to minimize damage to the walls.
One tip that helped me: Use the supplied fastening materials sparingly and supplement them with special tenant-friendly alternatives, such as clamp holders or bracket-like adapters that can be clamped between the furniture and the wall. This way, you avoid unnecessary drilling.
I also had good experiences asking the landlord in advance how many holes are acceptable or if cavity anchors are allowed before drilling. Most landlords are quite understanding if you communicate clearly.
Does anyone know if there are special floor leveling strips that help with uneven floors while also distributing the pressure?
Garry
12 Apr 2016 17:18
A few solid tips for installing Ikea Metod cabinets in rental apartments:
- First, carefully check the wall type (drywall, brick, concrete). For drywall, special hollow wall anchors are necessary and should not be heavily loaded.
- If possible, connect the cabinets to each other rather than only attaching them to the wall – this increases stability without creating too many holes.
- Mounting brackets made of aluminum or steel with a wide surface area are better than using just single screw points.
Regarding tools, I recommend a good rotary hammer for harder walls to create precise and clean holes, and a cable detector to avoid damaging electrical wiring.
To protect the rental property: there are so-called "furniture anchors" with rubber pads that reduce pressure on the wall, which is ideal for delicate walls. They are often not cheap but are worth it in a rental context.
A little patience in planning definitely pays off.
bareynaldo
13 Apr 2016 09:21
relupa schrieb:
Does anyone know if there are special floor leveling strips that help with uneven floors and also distribute pressure?
In my experience, these floor leveling strips are often more cosmetic than a real guarantee of stability. The main issue when installing in rental apartments is usually overcoming the fear of drilling.
People often say you’re not allowed to fix anything to the walls – but as long as you use the right anchors and properly fill the holes after moving out, landlords usually don’t have a problem. The fear of making holes is often exaggerated.
That said, if you want to be completely safe, alternatives like freestanding kitchen units or mounting rails without drilling are an option. Still, a bold statement: secure wall mounting is usually the better and more stable solution. It’s better to invest and renovate neatly afterwards than to live with shaky setups.
LEMAN
13 Apr 2016 13:49
Oh yes! Installation in rental apartments can be frustrating, but you can do it!!
Here are some tips that have made assembly easier for me:
- Always work precisely with a meter tape and a spirit level; the system is well designed, but even the smallest inaccuracies can cause alignment issues.
- For rental apartments, always double-check where you are allowed to drill – areas next to door frames or in corners are often off-limits.
- If possible, use special adhesive anchors for drywall that are designed to fit IKEA kitchens – very practical!
Very important: Allow plenty of time, this kind of installation is not a race! I have assembled with friends before – two pairs of eyes see more.
I’m really looking forward to you continuing to share your experiences here, it’s very motivating!!
