ᐅ What should you do if the back panel adhesive on a KALLAX unit comes loose?
Created on: 23 Aug 2022 08:17
FaleonaHello everyone,
I noticed that the adhesive holding the back panel of my IKEA KALLAX shelf has come loose in several places. The back panel is no longer firmly attached and seems like it might come off completely over time. My question is: What are the best options when the adhesive on the back panel of a KALLAX shelf starts to fail? Are there suitable glues or repair methods that provide a durable and clean result? I want to prevent the back panel from falling off entirely and compromising the shelf’s stability. If anyone has experience with re-gluing, replacement, or other repairs, I would appreciate a detailed description of the steps and any tips. Thank you in advance!
On the issue of attaching the back panel of the KALLAX shelf: This back panel is usually fixed with a thin layer of adhesive, which can easily come loose under stress or humidity. The most reliable solution is to completely remove the back panel, thoroughly clean the adhesive surface, and then apply a high-quality wood or construction adhesive. It is important to press the back panel correctly and allow extended drying times, ideally 24 hours.
Additionally, it is recommended to mechanically secure the back panel, for example with small nails or a fine stapler. This prevents it from detaching again due to tension or pressure. An alternative is to replace the back panel with a slightly thicker MDF board, which rests more firmly and can be glued securely.
For those seeking maximum long-term stability of the construction, the combination of adhesive and mechanical fastening should be chosen.
Niclas schrieb:
The back panel is usually attached with a thin layer of adhesiveThat’s exactly what I thought, the thin material is probably not ideal for long-lasting hold.
lajudo schrieb:
Additionally secure with a stapler or fine nailsHow exactly do fine nails work with the back panel? Do you have to pay attention to the material to avoid splitting?
I’m also curious whether it’s possible to re-glue with superglue if I only want to fix small areas and not attach an entire back panel. Or could that rather cause damage?
Hello Faleona,
to answer your questions regarding finishing nails and super glue:
Finishing nails (e.g., 10–12 mm (0.4–0.5 inches) long, very thin nails) are well suited for fixing the thin back panel made of plastic or thin particleboard. It is important to hammer them in very carefully to avoid splitting the material—using a small hammer and gentle pressure works best. If you are uncertain, you can pre-drill a small hole with a thin drill bit.
Super glue, on the other hand, is not ideal for bonding large surface areas of the back panel to the KALLAX, as it cures quickly but does not offer flexibility and can cause thin materials to crack. For small chipped areas or cracks, super glue can be helpful, but for a full bond you should use wood glue or construction adhesive, as these remain flexible and provide better adhesion.
I hope this helps!
I hope this helps!
