ᐅ KALLAX became unstable after moving it to the attic – how to stabilize it?
Created on: 23 Dec 2024 09:17
Nonben59
Nonben59
23 Dec 2024 09:17
I recently moved my KALLAX shelving unit and transported it to the attic. Now it is noticeably more wobbly than before, even though I assembled it exactly the same way. The floor is somewhat uneven, and the attic itself is not as stable as the previous room.
My question to the community: How can I stabilize my KALLAX shelving unit so that it stands securely in the attic and no longer wobbles? Are there specific techniques or materials that work well for fixing the unit in place? Are there differences in stability depending on whether the unit is positioned vertically or horizontally?
I appreciate any tips, and I’m also interested in hearing about your experiences with stabilizing a KALLAX shelving unit on uneven surfaces. Thanks in advance!
Jensson
23 Dec 2024 10:23
Hello Nonben59,
first regarding stability: The KALLAX shelf is generally quite sturdy but is designed for a flat, hard surface. On uneven floors, it can wobble easily, especially if it is not directly secured to the wall.
Here is a brief guide on how to make your shelf more stable:
1. Check the floor: Mark the highest and lowest points with a thin piece of wood or plastic so that the shelf can sit evenly.
2. Adjust the feet: IKEA offers adjustable feet that you can screw under the shelf legs. This helps to compensate for unevenness.
3. Wall mounting: Very important, especially in an attic with sloped ceilings. Use anchors and screws to fix the shelf to the wall (inner edge, back panel).
4. Cross braces: There are inexpensive metal brackets that you can screw onto the back to reinforce the shelf.
Regarding your question about vertical (upright) versus horizontal orientation – vertical usually provides more stability because the load is better distributed. Horizontal is more suitable for low, wide setups, but the footprint will be wider.
If you need more details, just ask!
Dilen
23 Dec 2024 11:45
To better understand the issue with the wobbliness and to find the best solution, a few more details would be helpful:
- How large are the uneven spots on your attic floor exactly? Are they just isolated or is the entire floor uneven?
- What type of floor covering do you have, for example wooden planks, OSB boards, or screed?
- Has the shelving unit been attached to the wall by you or someone else before, or is it currently standing freely?
For stabilization, I recommend the following steps:
1. Level the floor: Small unevenness can be compensated with small wooden strips or felt pads under the feet. For larger uneven spots, wooden wedges work best.
2. Optimize the feet: If you don’t want to fix it directly to the wall, adjustable furniture feet are a good option. These have a threaded nut that allows you to adjust the height with millimeter precision.
3. Frame-compatible reinforcement: The back panel of the KALLAX is made of thin particle board, which contributes little to the stability. You can replace it with a stronger back panel (e.g. OSB or MDF) to make the structure noticeably stiffer.
4. Wall mounting: If possible, highly recommended! Even a single screw attachment significantly increases resistance against tipping.
Please describe the floor surface in detail so I can give you more specific advice.
One more tip: Attic floors often experience temperature and humidity fluctuations — these can affect the material as well. So try to optimize not only the stability but also protection against moisture!
lisku
23 Dec 2024 12:30
Align the feet and use adjustable furniture feet or felt glides.
If possible, always fix it to the wall. This will prevent any wobbling.
Elijah42
23 Dec 2024 14:02
I completely agree. My KALLAX was a bit unstable when freestanding, but since mounting it to the wall, it’s as solid as a rock.
Filippo
24 Dec 2024 08:15
Hello Nonben59,
to look at the topic from a different perspective: Combining a KALLAX unit with an attic space is indeed challenging because the construction of many attics is not designed for perfectly level surfaces.
A few additional tips and background information:
- The KALLAX shelving unit is modular and designed for flat, rigid surfaces. The back panel is a thin particleboard that contributes very little to overall stability on its own.
- Unevenness under the feet can cause increased stress on screws and connectors, which can lead to wobbling over time.
- If you plan to keep the unit in the attic permanently, I would recommend adding a stiff back panel made from 8mm MDF board (about 0.3 inches), attached with small brackets on the sides. This greatly improves rigidity.
- Be careful when attaching it to walls with sloped ceilings: make sure to find the solid, load-bearing rafters behind the paneling; otherwise, the screw will hold no weight.
- As an alternative to brackets and screws, you can also use special furniture wedges made of plastic or wood to correct minor height differences.
How is the unit positioned exactly: is it placed directly against the slope or more centrally on the floor?
@Dilen: I agree that moisture and temperature fluctuations also play a role.
