ᐅ Is it sufficient to stabilize Kallax units using only brackets?
Created on: 25 Oct 2020 09:12
nontu
I am currently wondering whether it actually makes sense or is sufficient to stabilize an IKEA Kallax shelving unit solely with metal brackets (i.e., angle brackets, L-brackets), and if this makes the shelving unit permanently very sturdy.
Specifically, I am interested in whether such brackets at the connection points significantly increase stability to the extent that other reinforcement elements like back panels or additional crossbars can be omitted.
I like the idea of designing a Kallax shelving unit more freely, without a back panel, using only brackets—partly for aesthetic reasons and partly because it would make the unit easier to modify.
Does anyone have personal experience or professional knowledge on this? Will brackets on the sides and crossbars be enough to prevent the shelving unit from twisting or sagging? Or could this cause problems over time, even if the connections themselves are secure?
I look forward to your feedback and advice!
Traman4
25 Oct 2020 12:04
Brackets at all joints + securing to the wall = stable.
Without wall attachment, however, the shelf is at risk of tipping, even with brackets.
No back panel + brackets alone -> not permanently secure.
Palenar
25 Oct 2020 12:46
I would like to explain the technical principle in more detail:
A shelving unit like Kallax is designed as a frame structure—mainly with vertical sides and horizontal shelves. The stability against racking (shear deformation) depends crucially on the joint rigidity at the corners.
Brackets at the corners do increase the stiffness between the individual components; however, they primarily transfer tension and compression forces at these points. They do not, by themselves, prevent the entire shelving unit from shifting sideways under load because, without a back panel, the shelving lacks sufficient shear stiffness.
The back panel acts as a surface that prevents this shear-like deformation, making the shelving unit more torsion-resistant.
If you decide to use only brackets, ideally you should increase the number of attachment points, use high-quality brackets (preferably with a large bearing surface and multiple screws), and distribute the load evenly.
In principle, this is technically possible, but it is neither as secure nor as durable as using a back panel or diagonal bracing.
If you want to use the shelving freely in the room, I would also definitely recommend securing it to the floor and ideally adding a cross brace at the top or bottom—or you will have to incorporate a thin back panel as a design element.
LOSAR
25 Oct 2020 13:19
In short: brackets are helpful, but not sufficient.
Even with brackets that don’t have a back panel, over time you will get some play, and the shelf will either tilt or become wobbly.
Sometimes a thin board placed diagonally inside the shelf is enough to provide solid stability.
nontu
25 Oct 2020 13:43
Thank you for your previous answers!
Genevieve schrieb:
If you don’t have a back panel that provides surface stability, the brackets can cause the entire shelving unit to tilt or twist under load.
That sounds plausible to me.
I would prefer to avoid a back panel if possible, as it interferes with the appearance and lighting. I find the idea of thin diagonal braces (e.g., a thin metal rod) interesting.
Does anyone have experience with whether such a diagonal brace on a Kallax unit is practical and easy to install? What should I pay attention to in order to do this properly?
And how should the brackets be properly sized? Are there dimensions or thicknesses that are particularly recommended?
GUSTAVO56
25 Oct 2020 14:11
Here is an assessment regarding braces and brackets:
A diagonal brace made of metal – for example, a steel rod or a thin pipe – is an excellent solution to significantly reduce the shelf from twisting. It is important that it is installed from one top corner to the opposite bottom corner so it can effectively handle tensile forces.
Installation notes:
- The brace should be fixed at both ends with screws and angle brackets.
- Ensure a secure anchoring, otherwise the stabilizing effect will be lost.
Regarding bracket dimensions:
- For Kallax, I recommend angle brackets with legs at least 40–50 mm (1.5–2 inches) long and a material thickness of at least 2–3 mm (0.08–0.12 inches).
- Several smaller brackets distribute forces better than a few large ones.
- Galvanized or coated brackets are better because they are more durable and won’t rust indoors.
A clear focus should be on ensuring that screws penetrate deeply enough and the fastening does not damage the shelf material.
Do you plan to disassemble and reassemble the shelf often? Frequent screwing in and out can affect stability.
LAURE-TA
25 Oct 2020 14:43
Installing a diagonal brace is generally not difficult, but here are some practical tips:
- Measure accurately: The brace should fit snugly; otherwise, the overall rigidity will be lost.
- Secure attachment points firmly at the upper and lower edges using angle brackets with at least two screws per end.
- Even if the brace is not meant to be visible, it is better to install it on the inside.
- For wood, it is advisable to pre-drill screw holes slightly to avoid material splitting.
Regarding angle brackets: For a piece of furniture that is not frequently modified, flat brackets with 30–40mm (1.2–1.6 inches) legs and 2mm (0.08 inches) thick steel are strong enough.
If appearance matters, decorative brackets made of stainless steel or black powder-coated models are also available.
For loose or lightly loaded wood, self-adhesive brackets can be omitted, but they are not strong enough for load-bearing purposes.
