ᐅ What temperature range is the KALLAX suitable for in outdoor use?
Created on: 15 Jan 2022 08:17
ja-mo
Hello everyone, I’m wondering if the IKEA KALLAX shelving unit is suitable for long-term use outdoors. I’m especially interested in knowing what temperature ranges the KALLAX wood or MDF panels can withstand without sustaining permanent damage. Are there any experience-based insights or official information on this? I’m asking because I have a terrace where temperatures can drop below -10°C (14°F) in winter and can rise above 30°C (86°F) in summer. Would the shelf remain stable under these conditions over time, or should I consider a different option? Thanks in advance for any advice!
angel schrieb:
Unfortunately, there is no official temperature rating from IKEA, as the product is intended for indoor use only. Thank you, that sounds reasonable. I am curious if anyone has used the KALLAX, for example, in a covered porch during transitional seasons with frost and occasional moisture? Did it make a difference? Can durability be extended with some protection?ja-mo schrieb:
Can the durability be extended with some kind of protection? Sure, if you wrap it with plastic film and cover it, it will last a bit longer, but in the long run, it doesn’t make sense. It’s simply not designed for outdoor use. It’s better to use something made of metal or waterproof plastic 🍀Let's be honest, who puts a KALLAX outside in freezing weather and then wonders what happens? 😀 Solid wood or MDF outdoors is about as practical as using an umbrella in a storm inside the forest. If you really want something weather-resistant, you should invest in a professional shelving unit or basement shelving made of steel or plastic.
NOAHSAU schrieb:
Honestly, who would put a KALLAX outside in freezing temperatures and then be surprised? Well, I wouldn’t dismiss it that quickly—I think it’s good to clarify such practical questions before making a purchase. Especially since the KALLAX is often requested as a budget-friendly solution for outdoor use, it would be helpful to look at this more closely.I’m more interested in how much temperature stress the material can actually withstand, including exposure to moisture. Has anyone stored a KALLAX outside just over the winter? Or in an unheated garage?
