ᐅ KALLAX after Furniture Delivery – Warped or Construction Defect?
Created on: 25 Feb 2023 08:37
ErikafraHello everyone,
I am currently facing the following question: After transporting my IKEA KALLAX shelving unit, I noticed that the wooden panels have warped slightly along their entire length. Now I am unsure whether this is purely damage caused by improper storage or handling during the move, or if there might be a design flaw in the furniture itself that promotes such warping.
The shelving unit was stacked flat on its back during transport and was well padded, yet the warping is visible and also bothersome in everyday use.
I would be very interested in your experiences and opinions: Is this kind of warping typically due to external factors, or are there known design weaknesses in the KALLAX that could encourage this? Also, are there any tips on how to possibly straighten the panels again, or is that unlikely to work?
Best regards and thank you for your input!
flo-Theres25 Feb 2023 08:52Hello Erikafra,
Based on my experience with KALLAX shelving units, it should be noted that the material used—particleboard with a melamine resin coating—is prone to moisture damage and pressure deformations. Transporting it lying flat can indeed cause pressure marks, especially if the shelf is stored that way for a long time or if heavy objects were placed on it.
I am not aware of any design flaws from IKEA. The construction is generally sturdy, but due to the choice of materials, it is not indestructible.
If you want to try to straighten the shelf, I would recommend storing the furniture at room temperature without any load and, if necessary, carefully applying counterpressure to the affected panels to flatten them. However, a complete return to the original condition may be uncertain.
Hi Erikafra :-)
I once had to transport a KALLAX too, and the panels developed slight waves afterward – of course, they’re made of pressed wood and not as sturdy as solid wood.
That’s true! I think as long as you don’t stack the shelf incorrectly or overload it, the piece can handle quite a bit.
A tip from me: let the unit rest for a few days in the open air without any load; the material usually “relaxes” a bit 🙂
Good luck!
Good luck!
To the point: KALLAX shelves are made from medium-density fiberboard (MDF) with a melamine coating. This material is somewhat sensitive to moisture and mechanical stress, which can promote deformation.
During furniture transportation, compression and tension stresses are unavoidable. If the padding is insufficient or the shelf is under load for an extended period, permanent deformations may occur.
As far as I know, no structural defects related to faulty frame or panel construction have been documented.
Regarding remediation: It is hardly possible to completely reverse deformations. Moisture-assisted methods (light dampening and weighting) might help in some cases but carry the risk of causing further damage.
Conclusion: A transport-related deformation is more likely than a construction defect.
Hey Erikafra!
That warping issue is annoying, but hang in there! 🙂 The KALLAX panels are quite thin and delicate. Transport is often the main culprit.
But don’t worry: if you leave the shelf for a few days in a warm, dry place, it often settles out a bit.
And if you’re careful, you can gently shape the panels using tape or weights. You’ve got this!
Keep at it, you’ll manage!
