ᐅ Is KALLAX too delicate to use as a workshop cabinet?
Created on: 5 Oct 2015 07:34
tutous
tutous
5 Oct 2015 07:34
I am planning to use the IKEA KALLAX unit as a workshop cabinet to neatly store my tools and smaller equipment. However, I have often heard that the KALLAX is considered somewhat too delicate in terms of stability and durability for workshop conditions. My question is: Is the KALLAX really too sensitive for the harsher environment of a workshop, including exposure to moisture, dust, occasional impacts, or the weight of heavier tools? Or is its construction and material quality sufficient to use it effectively as a workshop cabinet with appropriate precautions?
I look forward to your assessments and experiences!
NoValentin
5 Oct 2015 08:12
The KALLAX is made from particleboard and is not designed for heavy loads. For tools, I would recommend a metal or more solid wood cabinet instead.
PULAU
5 Oct 2015 10:27
The KALLAX is generally more suitable for living areas rather than workshop use. The surface is laminated, which provides some resistance to moisture, but impacts and heavy loads can be problematic, especially when storing heavy equipment or tools. It is recommended to reinforce the back panel and shelves, possibly with additional bracing, to improve stability.
janeo
5 Oct 2015 13:04
NoValentin schrieb:
The KALLAX is made of particleboard and is not designed for heavy loads.
That is true, but the argument should not be generalized. It greatly depends on how it is used. If you only store light tools or small parts and position the cabinet properly, the KALLAX can actually be suitable.
PULAU schrieb:
The surface is laminated, which offers some resistance to moisture, but impacts and weight can be problematic.
That said, I wonder how often a workshop cabinet is really handled roughly. Many people use it mainly for storage rather than as a workspace. How exactly does the original poster envision using it?
tutous
5 Oct 2015 14:16
Thank you for the feedback so far.
Regarding the specific usage: it is not about work surfaces, but truly about storage. I intend to store somewhat heavier tools (e.g., a drill, cordless screwdriver, some metal parts). Also, tools might occasionally be put away or taken out with some force, so impacts may occur and cannot be entirely avoided.
Moisture is minimal in my case, more of a controlled indoor climate. Dust, however, does occur.
I have considered reinforcing the individual compartments with additional shelves to better distribute the load. How practical or advisable do you think this is?
KAMERON
5 Oct 2015 16:45
The KALLAX is structurally designed for household use, with a maximum load capacity of approximately 13-15 kilograms (29-33 pounds) per compartment. Heavier tools may cause the shelves to bend or the joints to come loose.
The reinforcement you suggested by adding extra shelves can help, but it requires that these reinforcements themselves are very securely installed. Additionally, the laminate provides only limited protection against moisture and mechanical wear.
A practical solution could be to store heavier tools in the lower compartments on sturdy metal boxes, which are then placed inside the KALLAX. This way, you reduce the direct load on the furniture.
