ᐅ Is it practical to use the Kallax as a radiator cover?
Created on: 7 Mar 2024 08:23
Dariobe63
I’m considering using my IKEA Kallax shelf as a cover for my radiator. My main question is whether the Kallax can function effectively as a radiator cover—specifically, if the heat can pass through well, if the shelf won’t be damaged, and if its functionality will remain intact.
Does anyone have experience with this or knowledge about the structural and thermal aspects? It would be interesting to know if wood or MDF panels, like those used in the Kallax, block heat or if the cover might even have a positive effect on heat output.
Additionally, I’d like to know if the shelf should be modified in any way, for example with ventilation slots or special materials, to avoid reducing heating performance.
Thanks in advance for any helpful advice!
gregto
7 Mar 2024 12:11
Hello Dariobe63,
Thank you for your detailed question!
Using a Kallax shelf as a radiator cover is definitely possible, but there are some technical aspects you should consider:
1. Material: Since Kallax is made of MDF and wood, these materials are insulating and can significantly reduce heat transfer.
2. Air circulation: As already mentioned, ventilation slots or open areas are essential to allow warm air to circulate in the room. A completely closed shelf blocks heat exchange.
3. Distance: Maintain a gap of at least 5 cm (2 inches) between the radiator and the shelf. This prevents heat buildup and protects the wood from damage.
4. Moisture: Radiators dry the air, but convection airflow can transfer moisture to the wood, potentially causing warping over time.
5. Alternative: You could also consider using heat-resistant paint or a thin metal sheet on the back of the shelf to improve heat and moisture protection.
If you keep these points in mind, the Kallax shelf can serve not only as a practical cover but also remain a piece of furniture with aesthetic value.
If you plan to store books or delicate items in the shelf, I would recommend avoiding that in the area near the radiator.
Paxton38
8 Mar 2024 07:45
From a technical perspective, a Kallax cladding made of wood or MDF naturally slows down heat transfer. It is important that it does not fit airtight against the radiator.
An efficient solution is to maintain a distance of at least 5 cm (2 inches), combined with sufficiently large openings for air circulation.
Additionally, it should be considered that the convection from the radiator—the warmed air—should not be obstructed by shelves. Otherwise, the heating performance will clearly decrease.
gregto schrieb:
If you plan to store books or sensitive items on the shelf, I would avoid doing so in the area above the radiator.
I would agree with that – heat and dry air can significantly damage books and other items.
gasidney
8 Mar 2024 08:17
Using Kallax as a radiator cover is possible, but without holes or spacing, heat gets trapped and the radiator operates inefficiently.
benon
8 Mar 2024 09:42
One more tip: If appearance is important, you can add a few extra ventilation elements to the Kallax. For example, small grilles on the sides or as a door replacement. This keeps the air circulation going while still making the furniture look good.
Additionally, air movement enhances the convection effect. A completely closed shelf can lead to higher heating costs because heat is not dissipated well.
Elijah42
8 Mar 2024 10:05
Ventilation slots and spacing – everything else is aesthetic, not functional. If you want to heat, you need airflow.
Dariobe63
8 Mar 2024 14:39
Thank you for the helpful answers!
Some of you keep mentioning “clearance.” To clarify: Is 5 cm (2 inches) clearance enough if I place the Kallax directly against the wall and there is a radiator behind it? Should I also allow ventilation space on the sides?
Additionally, I’m concerned that the radiator might be harder to access in summer for cleaning or maintenance because of the shelf. Is this an issue for any of you?
At the moment, I’m leaning towards modifying the shelf by partially removing the back panel and possibly installing ventilation grilles on the sides. Does anyone have recommendations for specific tools or materials for such modifications without causing too much damage to the shelf?
