Dariobe637 Mar 2024 08:23Hello everyone,
I’m considering using my IKEA Kallax shelf as a cover for my radiator. My main question is whether the Kallax can function effectively as a radiator cover—specifically, if the heat can pass through well, if the shelf won’t be damaged, and if its functionality will remain intact.
Does anyone have experience with this or knowledge about the structural and thermal aspects? It would be interesting to know if wood or MDF panels, like those used in the Kallax, block heat or if the cover might even have a positive effect on heat output.
Additionally, I’d like to know if the shelf should be modified in any way, for example with ventilation slots or special materials, to avoid reducing heating performance.
Thanks in advance for any helpful advice!
Hello Dariobe63,
Your question is very well considered and important, as wood or MDF as materials can have insulating properties. This means that a covering made from Kallax can affect the heating performance. Heat does pass through the shelf, but its release into the room is reduced if sufficient air circulation is not ensured.
To optimize this, I recommend ventilation slots either on the back or in the area of the radiator, so warm air can circulate. It is also possible to use heat-resistant paint or special protective coatings to prevent damage to the wood.
In addition, the shelf should ideally be placed with some distance, about 3-5 cm (1-2 inches), in front of the radiator to allow free airflow.
I hope this helps you with your decision.
I think it’s important to mention that Kallax shelves are usually made from particleboard, which naturally has insulating properties. This can restrict the flow of warm air, reducing the efficiency of the radiator.
I fully agree with this. Additionally, I would recommend not sealing the shelf completely and, if possible, omitting a back panel. Also, dust inside the shelf can affect air circulation.
It might also be helpful to attach a thin metal plate behind the radiator as a heat conductor. This supports heat distribution.
benon schrieb:
Ventilation slots either at the back or around the radiator area to allow warm air to circulate.
