ᐅ KALLAX and Thermal Stresses – Can This Cause Cracks?
Created on: 10 Feb 2020 08:23
enisbe
enisbe
10 Feb 2020 08:23
Hello everyone, I have a technical question regarding IKEA furniture, specifically the KALLAX series.
Can KALLAX shelves develop cracks in the material due to thermal stress?
I have often read that particleboard, in particular, can experience stress from temperature fluctuations or when furniture is placed near a heat source for extended periods, which may lead to cracks. I am interested in whether this is actually a concern with KALLAX shelves, especially since they are made from engineered wood panels, which do react to temperature changes.
Does anyone know the exact materials used in KALLAX? And are there any experiences regarding expansion, contraction, and resulting material damage? I look forward to well-informed answers!
korosu
10 Feb 2020 08:35
Yes, KALLAX is mainly made of wood-based panels with a melamine coating.
Thermal stress can cause cracks under high heat and poor ventilation. However, normal use is not problematic.
laume
10 Feb 2020 09:12
Hello enisbe,
I’m glad you addressed the topic so precisely.
The KALLAX shelves are actually made from medium-density fiberboard (MDF) with a melamine resin coating. These boards are sensitive to significant temperature fluctuations, especially when humidity changes at the same time.
Thermal stresses occur when different parts of the shelf heat up or cool down unevenly – this can cause the material to expand or contract unevenly. This is particularly true if the furniture is placed near radiators, open flames, or in direct sunlight, which over time can lead to stresses that may eventually cause cracks in the worst case.
Is your KALLAX already positioned in such a location?
enisbe
10 Feb 2020 09:47
laume schrieb:
Especially if the piece of furniture is near radiators, open flames, or direct sunlight, this can lead to stresses over time that may eventually cause cracks in the worst case.
That’s exactly right, the shelf is located next to a radiator, but with about 30 cm (12 inches) clearance.
Could this already be problematic? And if so, are there any preventive measures to minimize these stresses?
I’m concerned about long-term effects, such as the panels loosening or developing cracks due to expansion.
kulau
10 Feb 2020 11:05
To properly answer your question, several aspects need to be considered, so here is a more detailed explanation:
1. Material properties:
The KALLAX uses MDF or particleboard panels coated with melamine foil. MDF has a certain hygroscopic nature, meaning it absorbs and releases moisture, which also causes changes in volume.
2. Thermal stresses:
Individual parts of the shelf heat up more due to a nearby radiator or heater, creating thermal gradients. Different expansions can cause stresses in the material if the panels are not flexible enough or are rigidly connected.
3. Failure mechanisms:
These stresses can lead to cracks, delamination of the coating, or warping. Cracks often occur at edges or spots with mechanical weak points, such as screw holes.
4. Prevention:
- Maintain at least 30cm (12 inches) distance from the heater (preferably more)
- Ensure air circulation
- Use UV protection to avoid direct sunlight
- Avoid prolonged increased humidity
Measuring the surface temperature directly on the furniture could show how much it heats up.
I am interested to know: Are there any visible cracks already? Where exactly? How old is the shelf?
enisbe
10 Feb 2020 11:41
kulau schrieb:
Are there any actual cracks on your side yet? Where exactly? How old is the shelf?
The shelf is about 3 years old, and so far there are no visible cracks.
Occasionally, I notice small hairline cracks along the edges, but I have considered them normal signs of wear.
I will measure the temperature to see how hot the surface actually gets. Thanks in advance for the detailed advice!
