ᐅ How does a dehumidifier affect the KALLAX unit in a damp room?
Created on: 14 Nov 2017 07:18
jeko38
jeko38
14 Nov 2017 07:18
Hello everyone, I have a somewhat specific question: How does a dehumidifier affect the KALLAX shelving system from IKEA when placed in a damp room?
I am planning to set up a KALLAX in my basement, which unfortunately is often very humid, and I am wondering if a dehumidifier really helps to prevent damage such as mold, swelling, or unpleasant odors. I am particularly interested in whether the moisture is removed only from the air or if the moisture that the furniture has already absorbed can also be reduced.
Does anyone have experience with how effective dehumidifiers are in such cases and whether they can actually protect the KALLAX? Are there any tips for optimal use to keep the shelf in good condition for as long as possible? Thanks in advance!
jokau
14 Nov 2017 07:45
A dehumidifier primarily helps to reduce the humidity in the air. This prevents the KALLAX from absorbing more moisture, but it does not automatically remove existing moisture within the wood.
Sepele
14 Nov 2017 08:16
Hello jeko38, here is a more detailed explanation:
A dehumidifier reduces the relative humidity in the room, which directly decreases the moisture absorption of furniture like the KALLAX. Wood and wood-based materials absorb or release moisture to balance with the surrounding air. In a damp basement, the material is often swollen or already affected.
Moisture that has already penetrated the KALLAX does not disappear overnight. However, a powerful dehumidifier can gradually reduce the moisture content in the furniture over weeks or months by keeping the air drier and thus allowing moisture to diffuse out.
Proper air circulation around the furniture is also important: If the KALLAX is placed too close to the wall or directly on a damp floor, it will continue to absorb moisture.
In summary:
1. A dehumidifier prevents further moisture absorption.
2. Over time, moisture already inside the material can be reduced.
3. Optimal use means: dehumidify the air + do not place furniture directly on a damp floor + ensure good air circulation.
If you have any further questions, I’m happy to help!
lisbi
14 Nov 2017 08:47
Sepele schrieb:
It is also important to ensure proper air circulation around the furniture: If the KALLAX is placed too close to the wall or on a damp floor, it will continue to absorb moisture.
This point is very important. Moisture always moves from the floor or wall into the furniture. Unfortunately, a dehumidifier does not fully prevent this; it mainly affects the humidity level in the air.
I recommend placing the KALLAX on small feet or spacers to avoid direct contact with the floor and to allow air circulation. Additionally, the basement should be ventilated regularly to keep the humidity low.
GIPAPO
14 Nov 2017 09:11
Dehumidifiers help, but they are not a cure-all. The KALLAX will never be completely dry if it stands directly on the cold, damp floor.
So: dehumidifier + distance from the floor + regular ventilation.
jeko38
14 Nov 2017 09:29
Thanks in advance for the answers!
I understand that the moisture in the wood doesn’t disappear immediately, but I mainly wanted to know if using a dehumidifier will improve the condition of the KALLAX over the long term, or if the risk of mold and swelling remains when the furniture is only surrounded by dry air.
I also won’t place the shelf directly on the floor — small feet or plastic pads are planned. It would be interesting to hear if anyone has had experience with the KALLAX in a damp basement and whether the dehumidifier really helped noticeably.
