ᐅ Kallax Shelving and Radiators – Heating Issues?
Created on: 27 Jun 2021 08:43
Ivanle
Ivanle
27 Jun 2021 08:43
Hello everyone, I recently bought a Kallax shelf and plan to place it in my living room directly in front of the radiator. I am wondering: can the heat from the radiator affect the material of the Kallax shelf or cause any damage? I am especially concerned about whether the heat could impact the laminate or the joints in the shelf, as I have read that wood-based materials can swell or warp when exposed to continuous heat. What has been your experience? Has anyone encountered issues with 'Kallax and radiators – heat problems?' in practice, such as damage to the shelf or reduced heating efficiency? Thanks in advance for your experiences and tips!
sarla
27 Jun 2021 09:12
Basically, the Kallax shelf is made from coated wood fiberboard, which should be heat resistant. However, continuous exposure to temperatures above 50°C (122°F) can weaken the adhesive joints and, in extreme cases, cause deformation. It is also recommended to maintain a minimum distance of about 10 cm (4 inches) between the radiator and the shelf to ensure air circulation and avoid negatively affecting both the shelf and the heating performance.
Khalil
27 Jun 2021 09:34
It’s great that you bring up this topic! 🙂 I once placed my Kallax directly in front of the radiator, with no gap in between. After a while, I noticed the shelf became somewhat uncomfortably warm, but there was no visible damage. However, I would still recommend leaving a small gap to prevent it from getting too hot – this protects both the furniture and the heating system! 🙂
sarlo
27 Jun 2021 10:02
Hello Ivanle, I completely understand your concerns. Kallax furniture is quite sturdy, but prolonged exposure to the heat from a radiator can eventually cause the material to slightly expand or yellow. As sarlo already mentioned, it is important to maintain the proper distance and not block air circulation. Additionally, you can try placing a thin heat protection pad or a reflective foil between the radiator and the shelf. This will help prevent direct heat exposure.
Rensan3
27 Jun 2021 10:48
A gap of at least 10-15 cm (4-6 inches) is sufficient. I have not noticed any issues with heat. Do not turn the heating down too much.
PLOMA
27 Jun 2021 11:23
Hello Ivanle, I would like to provide a more detailed answer because I have studied the effects of heat on wood-based panels extensively. Kallax is made from medium-density fiberboard (MDF) with a melamine resin coating. The melamine resin layer is generally heat-resistant up to about 80°C (176°F), but this only applies to short-term exposure. Prolonged heat exposure, such as that from radiators with surface temperatures around 40–60°C (104–140°F), can cause stress in the material over months. The adhesive joints of the panel connections may weaken, resulting in reduced stability. Additionally, heat can alter the moisture content of the wood fiber material, causing slight swelling or shrinking. For this reason, I strongly recommend maintaining at least a 10cm (4 inches) gap and ensuring unrestricted air circulation. If the radiator emits a strong amount of heat, a heat-resistant panel behind the shelf could help reflect the heat. It would be helpful to know the size of your radiator and the surface temperature in your living room to better assess the situation.
