ᐅ My KALLAX unit feels swollen after water damage – is it salvageable?
Created on: 28 Feb 2020 08:47
Leore
Leore
28 Feb 2020 08:47
I am currently facing an issue with my KALLAX shelf from IKEA. Unfortunately, there was water damage, and since then the surface and material of the shelf feel quite spongy. The stability also seems affected; it almost appears as if the MDF panels have swollen.
My question is: Is it worthwhile to try and salvage this KALLAX, for example through drying or treatment with special products? Or is the damage too severe, meaning I should better opt for a new shelf?
I look forward to your opinions and experiences, especially if anyone has successfully repaired a wet KALLAX before.
Aimee
28 Feb 2020 09:12
Leore schrieb:
Surface and material of the shelf are quite unclear
If the material is truly swollen, drying usually does not help much. A better solution is to get a new shelf or replacement parts.
Kinbu
28 Feb 2020 09:36
Hello Leore,
Water damage to KALLAX shelves is often problematic because the panels are made of chipboard or MDF, which absorb water quickly and swell. You can initially dry the shelf thoroughly—preferably in a warm, dry place with good air circulation—but the swelling usually causes the material to lose its stability permanently.
Sometimes you can sand down swollen areas with fine sandpaper; for small damaged sections, replacement is possible. However, with extensive damage, replacement is usually the more practical solution.
If your concern is the appearance, you can repaint or cover the surface with a film later, but the internal structure often remains compromised.
Timofa
28 Feb 2020 10:05
Leore schrieb:
The stability also seems to be compromised
Oh dear, that really sounds like quite a soggy situation! ;-) My advice: first, let the KALLAX dry out thoroughly, maybe using a fan or placing it in warm sunlight. Once the wood is dry, you can carefully check whether it feels hard only on the surface or is soaked through completely.
If it feels truly spongy – recovery is almost impossible. Maybe a good reason for an upgrade with the new KALLAX edition?! 🙂
Roberta
28 Feb 2020 10:42
As an addition:
If you still want to save the shelf, be sure to check the corners and edges. This is usually where the wood swells first and the most.
If the stability is heavily compromised, it becomes difficult. When in doubt, it’s better to buy a replacement.
Kyler10
28 Feb 2020 11:16
From a technical perspective, KALLAX panels are made of particleboard or MDF boards coated with a foil. These materials are highly sensitive to moisture—absorbing water causes swelling, which irreversibly damages the material.
A spongy texture indicates that the structure has become softened and is usually not restorable through simple drying.
Salvaging the panels with chemical impregnation or other treatments is only recommended for very minor damage and is often not cost-effective.
In short: For everyday use, it is best to rely on a new or at least intact component to ensure safety and load-bearing capacity.
