ᐅ KALLAX Unit Removed Due to Water Damage – Is It Still Usable in the Garage?
Created on: 8 Nov 2022 08:32
CasimirHello everyone,
I recently removed a KALLAX shelving unit from my garage because there was water damage. The shelf was exposed to moisture for several days – fortunately, it is now dry, but I’m wondering if the KALLAX can still be usefully used in the garage after such exposure.
My main concern is about stability and durability: How well does the coated wood particleboard material handle moisture? Can it last long-term in a typical garage environment (humid, sometimes cold, temperate), or would it be better to dispose of the shelf and replace it?
Does anyone have experience with how resilient the KALLAX is after water damage? I’m also interested to know if it can be reused without special treatment or repairs, or if it’s better suited as a storage shelf in a dry area like the living room.
Thanks for your input!
Hello Casimir,
Great that you asked the question so precisely; that makes the assessment much easier. Regarding KALLAX after water damage: KALLAX is usually a particleboard shelf with a melamine coating, which is not waterproof but rather water-repellent.
If moisture was able to penetrate over several days, it is very likely that the particleboard has swollen or at least been structurally affected. This means that the shelf might have lost some stability.
What you can check:
1. Test spots to see if the material has become soft or spongy.
2. Look for any warping or bulges.
3. Perform load tests (e.g., carefully placing weights on individual compartments).
Without further treatment, such as drying and possibly sanding followed by sealing, there is a risk that the shelf will continue to absorb moisture and suffer more damage over time.
For use in the garage, the shelf is only suitable if it remains relatively dry and no additional moisture reaches it. If the garage stays damp, I would advise against it—better to continue using it in a dry room or replace it if possible.
In summary: The KALLAX shelf may have reduced load capacity after water damage and must be thoroughly checked for safe use. If you only load it lightly and keep it dry, continued use is quite possible.
If you have any further questions, feel free to ask!
What you can check:
Guyju schrieb:
If moisture was able to penetrate over several days, there is a high likelihood that the particleboard panels have swollen or at least been structurally compromised.I agree, even if you rely on the melamine coating. At IKEA, this is not designed for continuous exposure to water.
However, how certain are you that the shelving unit has completely dried through? Particleboard can still be damp inside without it being immediately noticeable from the outside. This can lead to mold risks and damage to stored items.
It’s also questionable whether the stability has actually been affected – this depends more on the thickness of the panels. KALLAX is generally quite sturdy, but the adhesive in particleboard is sensitive to water.
I would suggest you also check the smell of the shelving unit for mold or mustiness. If it feels solid and smells fine, that’s a good sign. Otherwise, it’s really better to replace it.
My thought: using it in the garage only makes sense if you can ensure the environment remains dry and well-ventilated. Otherwise, the effort may be wasted.
Hello Casimir,
To answer your question more precisely, it would be helpful to know how long the KALLAX was exposed to moisture and what the temperature conditions were. The type of water damage (splash water, standing water, heavily soaked) is also important.
The construction of the KALLAX is indeed particleboard with a melamine coating, a very inexpensive material that swells quickly, softens, and loses the adhesive strength between the chipboard layers when exposed to moisture.
Here is an overview of what can happen:
- Swelling: The core material absorbs water and expands, which appears as waves or bulges.
- Glue failure: The individual layers can separate.
- Loss of stability: The shelf can warp, deform, or become unstable.
- Mold: If the material stays damp for a long time, there is a risk of mold growth.
My suggestion for your approach:
1. Dry it thoroughly, ideally over several weeks in a warm, well-ventilated environment.
2. Check for visible deformations and see if the material is soft or crumbly in certain areas.
3. Test its load-bearing capacity before placing heavy items on the shelf.
4. Optional: Treat the surface and edges with a wood protective varnish or sealant.
For garage use, its usability strongly depends on how humid it remains there. A lightly loaded, dry storage space may still be possible. However, for heavy loads or permanent use without protection, I would advise against it.
Do you have specific plans for the shelf, or do you just want to continue using it for storage?
Surela schrieb:
Are there any specific plans for the shelf, or do you just want to continue using it for storage?Thank you for the detailed assessment!
My plan is actually to keep using the KALLAX in the garage as a storage unit for tools, spray cans, and similar items. It doesn’t need to support heavy loads but should definitely be sturdy enough not to give way under some weight.
The moisture came from water seeping in from outside, which remained pooled for a few days and was only partially covered. Temperatures were typically cool, around 5-12°C (41-54°F). After the water damage, I immediately removed the shelf and moved it to the dry hallway inside the house.
I didn’t want to treat the surface because I’m not interested in painting or oiling it.
I hope it will be sufficient for its purpose. I can see some slight warping at the edges in places, but the surface still feels stable.
