ᐅ Using Kallax as a wardrobe cabinet – how resistant is it to dirt?
Created on: 21 Feb 2022 09:17
glafe
glafe
21 Feb 2022 09:17
Hello everyone, I am currently considering using my Kallax shelf as a wardrobe cabinet, especially in a utility area where dirty jackets and shoes are often handled. I am particularly interested in how resistant to dirt such a Kallax actually is. The MDF panels are lightly coated, but how durable are they against dirt, moisture, or stains? Does anyone have practical experience with how easy it is to clean the Kallax or whether it is suitable for use as a wardrobe solution in a dirty environment? The cabinet would regularly hold damp or somewhat muddy clothing. I look forward to your assessments and recommendations!
Kolepau
21 Feb 2022 09:45
Hey glafe, it’s great that you’re thinking about this! :-) I’ve been using my Kallax by the front door as a coat rack replacement for over a year now. Of course, it’s not ideal for direct contact with wet jackets, but I use hooks inside it and place a shoe mat underneath. Stains can usually be wiped off easily with a damp cloth! I would recommend waterproofing the Kallax well or at least covering it with a water-resistant film, then it’s really durable. Definitely doable!
karlau
21 Feb 2022 10:09
I find the question interesting, but I am somewhat surprised by the common use of Kallax as a wardrobe cabinet. The product is primarily designed for light storage and not for damp environments.
Kolepau schrieb:
Stains can usually be wiped off well with a damp cloth!
That may be true, but you can hardly expect the material to withstand prolonged exposure to moisture. Other materials, such as metal or specially treated wood, are certainly more suitable for that purpose. The Kallax fronts already showed slight swelling at the corners after just a few months, even though I was fairly careful.
BOLUKEO
21 Feb 2022 10:17
Kallax is not waterproof. Stains usually come off with a damp cloth, but prolonged exposure to moisture causes problems. It is better to protect it with a foil or plastic cover when used as a wardrobe.
Z
zarJody68
21 Feb 2022 10:45
MDF panels, like those used in Kallax, typically have only a thin melamine resin coating. This provides a certain surface hardness and makes the cabinet largely resistant to normal wear and tear. However, the surface is not completely waterproof, and prolonged exposure to water can cause the edges to swell. Removing stains is usually easy if they are fresh and have not deeply penetrated.
If the Kallax is used as a wardrobe solution, additional protection should be considered, such as a water-repellent layer or avoiding water dripping directly onto the surface. Alternatively, inserts or special coatings (e.g., clear varnish) can be applied to enhance the protective effect.
Domau0
21 Feb 2022 11:12
As a supplement to the previous information: The standard melamine coating on the Kallax provides a smooth, easy-to-clean surface, but it is not designed as a water-resistant protective layer.
If moisture, mud, or dirt comes into direct contact with the edges or surfaces and remains for an extended period, the material can swell or discolor.
For use as a wardrobe cabinet, I recommend:
1. Using shelves with waterproof film or laminate.
2. Attaching sealing strips to the edges to minimize direct exposure to moisture.
3. Regular cleaning with mild cleaners; avoid harsh chemicals as they could damage the surface.
It would be helpful to know what type of dirt is most common—dry dirt like dust or wet stains? Are there issues with dog paws or similar? Maybe we can specify this further.
