ᐅ Has anyone ever built an aquarium stand using a Kallax unit?
Created on: 30 Jul 2022 20:11
Gifapeo
Gifapeo
30 Jul 2022 20:11
Hello everyone, I am considering building a stand for my new aquarium myself. I came up with the idea of converting an IKEA Kallax shelving unit into an aquarium stand.
Has anyone here had experience converting a Kallax shelving unit into a stable and secure stand for an aquarium? I am particularly interested in aspects such as load-bearing capacity, suitable methods for reinforcement, protection against water damage, and practical tips for implementation. How did you modify the unit to withstand the weight of water and equipment and remain stable over time?
I look forward to your experiences and advice!
Blavin
30 Jul 2022 20:29
Gifapeo schrieb:
Has anyone here already had experience converting a Kallax shelf into a stable and secure base cabinet for an aquarium?
Basically, a Kallax shelf is designed for books and lightweight items, not for aquarium loads. The maximum load capacity per compartment is usually around 13-15 kg (29-33 lbs). However, an aquarium itself with water and equipment brings a significantly higher load. For a stable and secure base cabinet, a comprehensive reinforcement of the structure is necessary. This can be achieved using wooden boards, metal brackets, and especially by joining multiple Kallax units together.
Gifapeo schrieb:
How did you modify the shelf so that it can withstand the load from water and equipment and remain stable in the long term?
A waterproof seal or an additional protective layer should also be applied to prevent damage from moisture, since the Kallax furniture is made of particleboard.
My advice: Make sure to check the weight of your aquarium with all accessories and plan new reinforcements accordingly. If you plan to use the base cabinet for a larger tank, I recommend an additional sturdy wood frame construction behind or under the shelf.
meoreo
30 Jul 2022 21:02
I once reinforced a Kallax unit with wooden slats and protected it with varnish. This works well for small tanks up to about 40 liters (10.5 gallons). I wouldn’t recommend using it for larger tanks.
klo61
30 Jul 2022 21:47
I really like the basic idea since Kallax is affordable and modular.
It’s important to protect the shelving units from moisture. You can do this with waterproof varnishes or films. Also, instead of the original back panel, you should install a more stable version.
The key points to keep in mind are:
1. Load capacity: A fully filled aquarium combined with equipment is very heavy. The Kallax shelf must be able to support the weight evenly.
2. Stability: You can add extra cross braces or wooden panels inside for reinforcement.
3. Water protection: Apply protective coating to all surfaces, and carefully seal the cut edges.
If you’re unsure, I would recommend strengthening the shelf with an additional base made from OSB boards or multiplex plywood, which will distribute the load better.
Good luck with your project!
teyosef
30 Jul 2022 22:06
To document the conversion of a Kallax shelf into an aquarium stand clearly, I recommend the following approach:
1. Preparation: Measure the aquarium including all equipment and emergency ballast (water, gravel, decorations). Estimate the total weight.
2. Reinforcement: A simple method is to install a frame (made from sturdy timber beams) underneath the shelf base. This way, the load is directly transferred to the vertical side panels.
3. Water resistance: Kallax is made from particleboard, so all surfaces should be sealed with a waterproof varnish or coated with epoxy resin. Pay special attention to sealing cut edges thoroughly.
4. Assembly: If the Kallax depth is insufficient, add extra supports on the top side.
5. Avoid pressure points by placing a thin rubber mat (aquarium underlay) under the aquarium.
Common mistakes include insufficient reinforcement and lack of sealing. Please note that even with reinforcements, a Kallax shelf is generally not suitable for larger aquariums.
praWarre69
30 Jul 2022 23:25
meoreo schrieb:
I once reinforced a Kallax with wooden strips and protected it with varnish.
That sounds like a simple DIY trick that really makes a difference! 🙂
I always thought it was great when the base cabinet provided not only stability but also a bit of charm. For example, covering it with contact paper on the outside or adding some paint. And of course, always keeping it away from water with proper sealing.
A bit of improvisation is part of the fun when you want to get creative with a Kallax. But for larger aquariums, it’s better to play it safe!
