ᐅ What storage options are available with IKEA PLATSA?
Created on: 12 Jul 2021 08:43
gejado
gejado
12 Jul 2021 08:43
I’m interested in different storage options using IKEA Platsa and wanted to ask the community: What variations or ideas are there to make the PLATSA cabinet as versatile and functional as possible for storage?
Specifically, I’m curious about combinations of open and closed sections, the use of drawers or shelves, and whether anyone has practical experience with accessories like adjustable shelves or specialized inserts.
I’m planning to assemble a cabinet that can be used both in a living area and in an office, so it would be great if you could describe the possible uses in as much detail as possible. Thanks in advance!
GUSTAVO56
12 Jul 2021 10:21
Hello gejado,
to clearly explain the functionality and flexibility of IKEA PLATSA, I would like to go into detail about the various storage options this system offers.
First, PLATSA is ideal for adapting to different room layouts due to its modular design. There are basic units in different depths (35 cm (14 inches) and 56 cm (22 inches)) that can be installed either freestanding or wall-mounted. This allows for creating storage spaces of various sizes.
- Open compartments are perfect for keeping everyday items within easy reach or displaying decorative objects.
- Closed fronts with doors protect against dust and provide a tidier appearance.
- Drawers can be configured deep or shallow—ideal for organizing smaller items such as office supplies or textiles systematically.
- Shelves are made of metal and adjustable, meaning the height can be flexibly adapted to the contents.
A tip: For combined living and working areas, units with sliding doors are very practical. They save space when opening and contribute to a clean look.
I’m curious: What specific items are you planning to store, or what main function should the cabinet serve? Then I can provide more targeted recommendations.
Kinbu
12 Jul 2021 12:15
Hello gejado,
I would like to add, based on my experience as a user and in addition to GUSTAVO56’s comments, that PLATSA stands out especially because of its flexibility, particularly when it comes to combining open and closed elements.
In my case, I used a combination of open shelving units to keep frequently used books and decorations visible. At the same time, I set up closed compartments with doors for file folders and other office supplies, as otherwise the space would look cluttered.
- I use drawers for cables, stationery, and small office accessories that otherwise tend to get lost.
- The ability to modify each unit as desired helped me make the most of different ceiling heights or niches.
If you’re planning to use PLATSA in a corner or under sloping ceilings, there are hardly any other systems that can be customized so precisely.
If you like, I can gladly provide examples of how I combined the individual modules.
hauklo
13 Jul 2021 09:37
To add to this, I would like to clearly address the technical aspects of storage options with IKEA PLATSA.
The system is based on wood-based panels with high-quality fittings that ensure both stability and flexible expandability. Especially noteworthy are the three different module heights (64 cm, 128 cm, and 192 cm (25 inches, 50 inches, and 75 inches)), which allow for height variations.
Important for use:
- Pay attention to the load limits per shelf (usually around 10–15 kg (22–33 lbs)) to avoid deformation.
- Use the included assembly aids carefully, as incorrect installation can quickly lead to instability.
The storage options with PLATSA are therefore technically designed for demanding, even heavy use – so you can confidently store not only clothing and books but also electronic accessories or large binders.
Additionally, a variety of inserts such as clothes rails, drawer boxes, or drawer inserts are available to further organize your storage.
Hopefully, this structured overview helps you optimize your planning.
Genevieve
13 Jul 2021 12:05
I would like to offer a critical perspective, even though I generally appreciate the system.
In the discussion about the versatile storage options of PLATSA, I notice that while modularity promises maximum flexibility, it can also become a problem. Often, solutions end up looking visually inconsistent, especially when different types of fronts are combined without a well-thought-out plan.
GUSTAVO56 schrieb:
One tip: For combining elements in the living and working areas, units with sliding doors are quite practical.
I generally agree with this, but I would add that sliding doors are more difficult to install and repairs can be troublesome, especially if you are not very experienced in furniture assembly.
Furthermore, it is important to clearly define the primary storage function in advance to avoid mixing too many different types of components, which can create more confusion than benefit in the end.
How does gejado plan this? Is appearance or functionality the main priority?
gejado
15 Jul 2021 07:54
Genevieve schrieb:
How is gejado planning this? Is the main focus on aesthetics or functionality?
Thank you for the hint, Genevieve. In my case, the priority is actually more on functionality, as I mainly want to use the cabinet for office storage, but since it will be placed in the living room, it shouldn’t be visually obtrusive either.
I think I want a clear separation between open sections for items I need to access frequently and closed compartments for less attractive things. Sliding doors sound practical, but your concerns about installation are making me a bit uneasy.
Does anyone have experience whether a non-professional can install sliding doors on PLATSA in an organized and stress-free way? Or would it be better to opt for hinged doors?
Also, I’m interested in any practical tips you might have for integrating drawer systems into PLATSA that don’t look too bulky but still offer plenty of storage space.
