ᐅ How can Ikea Pax wardrobes be optimally organized for children's clothing?
Created on: 9 Mar 2017 08:12
Kekin35
Kekin35
9 Mar 2017 08:12
Hello everyone, I would like to start a detailed discussion on the topic: “How can an Ikea Pax wardrobe system be designed for optimal organization of children’s clothing, so that different sizes, seasonal changes, and various types of garments (e.g., pants, tops, rompers) are stored clearly and are quickly accessible?” I recently bought a Pax myself and am currently facing challenges with the layout. I am especially interested in how to make the best use of the limited storage space, which shelves or inserts are useful, and if you know any proven tips to keep the order for a long time. Also, any advice on how to adapt the system as the child grows without having to constantly reorganize everything would be appreciated. Thanks for sharing your experiences!
CHENNE
9 Mar 2017 08:40
A well-planned organization system in the Ikea Pax wardrobe is definitely achievable if you first consider which types of clothing need the most space and how frequently you access them. For children’s clothing, I have found the following structure to work well: - Upper shelves for off-season or rarely used items. - Middle drawers with dividers for segmented areas like onesies, T-shirts, and long-sleeve shirts – these hold the pieces needed daily. - Lower larger compartments with pull-out boxes for pants and bulkier clothing. I also recommend clearly labeled or color-coded inserts so that, with a bit of habit, each item is quickly placed in the right spot. Sustainability-wise, it’s important to regularly declutter, especially because children outgrow clothes so fast.
REOHEINRIC
9 Mar 2017 09:03
It is important to divide the wardrobe into zones: smaller drawers for underwear and accessories, medium-sized drawers for tops and trousers, and larger shelves or boxes for seasonally thicker clothing. With a Pax system, flexible reorganizations can be made using shelves and drawers. I also recommend designing the dimensions with the age group in mind and incorporating flexible elements that can adapt as they grow. Without clear zones, it is easy for the organization to suffer.
HORST41
9 Mar 2017 09:28
I completely understand you; organizing children’s clothing really comes with many challenges – especially when the little ones need new sizes almost every week! What has helped me was working systematically with labels and colors, so that even in low light or stressful moments, I don’t have to search for ages. I also have a kind of “transition drawer”: it holds clothes that are next in line, meaning the next size reserved for use soon. This way, you have a buffer that makes sorting easier.
reoWilhelm
9 Mar 2017 09:54
Very nice topic! I just want to quickly mention that having a bit of flexibility in the system really pays off – ideally modular inserts that can be moved around. For example, you can use narrower, taller compartments for very small items, and store wider boxes low down for larger things you can reliably reach for. I assume time is often tight when getting dressed – nothing should be rattling around or slowing you down searching. – By the way: for seasonal clothing, I have a small rolling cabinet outside the closet. 🙂
Renegi
9 Mar 2017 10:23
You should definitely buy inserts with compartments for the drawers. For children’s clothing, narrow sections are useful to keep everything well organized, for example for socks, underwear, and bodysuits. Tops, on the other hand, can be neatly folded and placed in larger compartments. Also, use hooks for jackets and hats, as this saves space.
