I’m facing the challenge of fitting Ikea Platsa units into a very tight space and would appreciate advice on how to best redesign the furniture to make the most of the available area. Specifically, it’s a small niche about 1.20 m (4 feet) wide with limited depth, where I want to create storage without making it feel cramped or restricting movement.
Has anyone had experience adapting Platsa for such narrow spaces? What solutions for cabinet layout, door or front options would you recommend? Are there any tips on modularity I should keep in mind? I’m looking forward to concrete suggestions or examples of how you’ve solved a similar situation.
Gloriagl1026 Mar 2024 10:45Hello Ezelsin, I would recommend using the Platsa modules with the shallowest depth and possibly incorporating open shelves to avoid a cramped feeling. Sliding doors instead of hinged doors also save space. Take a look at combining them with drawers to better organize storage.
Hello Ezelsin,
your concern is very understandable. Ikea Platsa is flexible, but it is important to plan the dimensions carefully, especially in tight niches like yours. I recommend measuring the space precisely first and then choosing the smallest available modules, possibly also considering high-quality sliding doors, as they make access easier without losing space due to doors swinging open.
Additionally, you can use interior organizers or boxes to adapt the storage space to your needs. It is also important to arrange everything so that frequently used items are more easily accessible. Have you already thought about stacking individual modules or placing them side by side?
The basic strategy for tight spaces with Ikea Platsa is to choose appropriate module depths: Platsa typically offers modules in 35 cm (14 inches) or 56 cm (22 inches) depth, with the 35 cm (14 inches) version being more suitable for very narrow rooms.
- Installing open fronts or those with sliding doors reduces space needed for door clearances.
- A combination of tall cabinets and lower units can be used to make optimal use of the available storage space.
I recommend using the flexible interior fittings (shelves, drawers) to accommodate items of different heights. This allows for more efficient use of the space.
Important: Having an accurate room layout before ordering prevents purchasing mistakes.
Hey Ezelsin!
Small rooms can sometimes be really challenging, but that’s where true interior design skills come into play. Fortunately, Platsa offers many clever options. Maybe consider angled combinations? For example, a slim box unit on one wall and the next unit on the adjacent wall – this saves space and creates a more open feel.
And very importantly: check out the fronts with glass doors; they look visually much lighter! If storage needs to go up high, grab small step ladders so you can easily reach everything without large doors.
Good luck with your remodeling!
Just a thought: How certain are you that Platsa is the best solution for your tight niche? Especially in very limited spaces, the modular design can sometimes be counterproductive if you constantly run into the limits of the modules.
That’s true, but aren’t those sliding doors with Platsa relatively expensive, and don’t they also take up some interior space?
I would also consider other options, maybe a custom-made solution or shelving systems with adjustable shelves, before committing to Platsa.
