ᐅ What should be considered when cleaning IKEA BRIMNES stainless steel handles?
Created on: 14 Jun 2020 08:37
lenlo57
lenlo57
14 Jun 2020 08:37
Good morning everyone, I recently bought a Brimnes bed from IKEA with stainless steel handles and am now looking to optimize the cleaning process, as I want to keep the handles as clean as possible in a gentle but effective way. This raises the question: What should be considered when cleaning IKEA BRIMNES stainless steel handles to maintain their shine and avoid damage from improper cleaning methods? I am especially interested in which cleaning products are recommended, whether abrasive cloths or sponges should be avoided, and how often the handles should be cleaned to effectively remove dirt while minimizing material wear. Does anyone have experience with IKEA BRIMNES stainless steel handles and can offer tips or advice on proper care and cleaning? Thanks in advance!
letar
14 Jun 2020 09:26
For targeted and gentle cleaning of the stainless steel handles on the BRIMNES bed, I recommend the following methods:
- Use only mild cleaning agents, ideally pH-neutral or mildly alkaline all-purpose cleaners. Avoid highly aggressive products or those containing chlorine, as they can cause corrosion or discoloration.
- Use soft microfiber cloths or sponges to prevent micro-scratches on the surface. Abrasive materials, such as steel wool or scouring pads, are not suitable.
- For stubborn stains, a mixture of warm water and a small amount of vinegar or citric acid can be used sparingly, as acids can damage the surface if left on too long.
- Always dry the handles immediately with a soft cloth after cleaning to prevent water spots and lime deposits.
- Cleaning frequency: Generally, cleaning once a week is sufficient, but it can be done more often with heavy use or visible dirt.
This approach ensures long-lasting preservation of the attractive appearance of the stainless steel handles and minimizes mechanical or chemical damage.
JUHAU
14 Jun 2020 10:04
This is important. I would also recommend avoiding cleaning agents with abrasive particles. Usually, warm water and a mild dish soap are sufficient. Afterwards, dry thoroughly.
BOSULE
15 Jun 2020 11:52
lenlo57 schrieb:
What should be specifically considered when cleaning IKEA BRIMNES stainless steel handles to maintain their shine and avoid damage from improper cleaning methods?
An important tip is to clean the handles regularly but gently to avoid damaging the protective layer on the stainless steel.
- Avoid chloride-containing cleaning agents, as chlorine can damage this layer.
- For stains or fingerprints, specialized stainless steel cleaners that cleanse while adding a protective layer are recommended.
- Do not use abrasive or scouring cleaners.
Occasionally, you can apply a soft cloth with a small amount of olive oil or specialized stainless steel care products to build up a protective layer that keeps the handles clean and shiny for longer.
This helps to maintain the desired condition over time.
