ᐅ What issues can arise with Ikea HEMNES furniture in rental apartments?
Created on: 8 Aug 2022 18:07
Medikau
Hello everyone, I’m considering getting the Hemnes wardrobe from Ikea for my rental apartment, but I’ve heard that such furniture can sometimes cause problems in rental properties. What specific issues have you encountered when installing or using Ikea HEMNES furniture in rental apartments? I’m especially interested in things like problems with wall mounting, damage from assembly that could cause trouble when moving out, or difficulties related to the size and flexibility of the wardrobe in smaller rooms. If anyone has practical experience or knows about potential risks, I would really appreciate a detailed assessment!
It is understandable that many people worry about damage to rental apartments. Concerns about wall fixings and potential defects when moving out show how important it is to handle the furnishings carefully.
One should be aware that some materials used for walls are more delicate (e.g., drywall panels). If you are unsure, it can help to ask the landlord for permission or advice, which can help avoid misunderstandings.
Sometimes it also helps to consider alternative solutions, such as freestanding or lighter furniture models, to reduce stress.
For context: The Ikea Hemnes wardrobe is known for its solid wood construction, which provides durability but also results in relatively high weight. This is often underestimated and can easily cause issues with wall mounting if not installed properly.
- In rental apartments with thin walls or delicate plaster, drilling for wall plugs can cause cracks or chipping.
- Proper installation with suitable wall plugs and screws is necessary, ideally with advice from a building supply store.
- When moving out, drill holes should be neatly filled with appropriate materials.
The wardrobe should also be emptied before moving it to avoid damage to the back panel. This panel is only about 3 mm (0.12 inches) thick and is not load-bearing.
Conclusion: Problems can arise from improper installation and handling but can be easily avoided with good preparation.
letar schrieb:
In rental apartments with thin walls or delicate plaster, drilling for anchors can cause cracks or chipping.I see this as the main issue as well. The cabinet itself is sturdy, but the building conditions in rental apartments often cause problems, especially when there are no reinforcements in the wall.
I would suggest performing a small material analysis of the wall before installation and possibly considering special solutions, such as clamp or floor fixings, if wall mounting could cause serious damage.
