ᐅ What issues can arise with Ikea HEMNES furniture in rental apartments?
Created on: 8 Aug 2022 18:07
Medikau
Medikau
8 Aug 2022 18:07
Hello everyone, I’m considering getting the Hemnes wardrobe from Ikea for my rental apartment, but I’ve heard that such furniture can sometimes cause problems in rental properties. What specific issues have you encountered when installing or using Ikea HEMNES furniture in rental apartments? I’m especially interested in things like problems with wall mounting, damage from assembly that could cause trouble when moving out, or difficulties related to the size and flexibility of the wardrobe in smaller rooms. If anyone has practical experience or knows about potential risks, I would really appreciate a detailed assessment!
faso31
8 Aug 2022 19:13
The question is valid, especially for rental apartments where consideration and easy installation are important. However, it is worth critically assessing whether the typical issues reported with Ikea HEMNES furniture are specific to this series or if they generally apply to furniture in rental properties.
It is often mentioned that wall mounting can be challenging because many HEMNES cabinets are quite heavy and come with only small anchors or simple brackets. This can potentially damage walls during installation in some rental units. However, I expect that with normal care and use, such damage should be minimal.
Are there reliable reports of installation or removal causing significant damage that led to conflicts when moving out? I would like to understand how common these problems are before forming my own opinion.
bauku
8 Aug 2022 20:41
I have the HEMNES wardrobe myself in a rental apartment and can only share positive experiences! 😊 Of course, installation requires care, but if you use the right type of wall anchor, there won’t be any issues with the wall. It’s important to properly fill the drill holes when moving out to avoid any problems! 😃
Size can sometimes be a concern in small apartments, but the wardrobe is really versatile and many compartments offer great storage space! So, go for it – just get started with the assembly! 🎉
jeff65
9 Aug 2022 08:22
Regarding the rental apartment and the HEMNES, I can offer a practical tip: Wall mounting is generally required to prevent tipping hazards. It is worth using appropriate anchors and screws that can be removed again when tenants change, without causing extensive damage.
You should also check whether the wall type (e.g., drywall, plaster, tiles) allows for secure mounting or if additional measures are necessary.
As for the space: The wardrobe is relatively large, so measure beforehand to ensure it doesn’t make the room feel cramped. I recommend using planning apps or sketches before purchasing.
Hannah
9 Aug 2022 09:18
Another issue is that the back panel of the HEMNES cabinet is quite thin and can be easily damaged if the cabinet is moved frequently. This can be a problem, especially in rental apartments where people sometimes relocate.
Additionally, during assembly, it is important to ensure that all connections are tight; otherwise, the cabinet will be unstable.
Davidleo
9 Aug 2022 11:54
At first, I was very worried about how the cabinet would be accepted when mounted on the wall in the rental apartment, but with the right materials and a bit of patience, it worked perfectly! 💪👍
Tip: Use screw caps to keep everything looking neat, and you can remove them later without leaving any marks. If you fill in all the holes before moving out, you usually won't have any issues with the landlord! 🚀
