ᐅ Are there any tips for assembling the IKEA Hemnes furniture without assistance?
Created on: 25 Sep 2017 14:23
par41
par41
25 Sep 2017 14:23
I’m about to start the project of assembling an IKEA Hemnes wardrobe completely on my own—without any help. My question is for anyone who has done this before or has experience with it: Are there any useful tips or tricks for completing the assembly efficiently and without outside assistance?
I’m especially interested in how to best organize the individual construction steps and whether there are specific tools or methods that have proven effective in practice. More than general motivational advice, I’m looking for a practical guide that takes into account the challenges and potential pitfalls of assembling the Hemnes system solo.
Thanks in advance for your helpful answers!
Svenja7
25 Sep 2017 15:12
Hello par41,
your question is very clearly formulated, which makes it easier to help you.
From my experience with Hemnes furniture, I can say that the key is to prepare each assembly group systematically. Take the instruction manual page by page and sort the screws and parts before you start. A color code or small bowls can help with this.
It is also very helpful to have a stable surface for large back panels or the carcass. If you are really working alone, it is worth partially assembling the carcass first and then leaning it against a wall for more stability.
Tools: A cordless drill with a torque limiter prevents you from overtightening screws (a common issue with Hemnes). A hammer is essential for dowels.
I’m happy to provide more details if you like.
JONKO
25 Sep 2017 15:45
I find this topic really interesting because I have often assembled furniture on my own – and yes, Hemnes can be quite tricky at times.
First of all: It’s completely normal to feel frustrated or like you’re stuck at some point. The important thing is not to rush and to take breaks when needed.
One thing that helped me a lot was reading through all the steps carefully beforehand and then working through them methodically, step by step. It’s also important to keep checking that you haven’t mixed up any parts – Hemnes sometimes uses very similar screws.
Sometimes you seem to get stuck, but after a short break it usually goes more smoothly. So don’t be afraid to take your time!
LuMarcel43
25 Sep 2017 16:08
I’m wondering if the typical assembly of Hemnes is really practical without any help.
Many people struggle with heavy parts or aligning the components properly. The assembly itself is only part of the challenge – handling the parts and securely fixing them to the wall, for example, often present obstacles for those building alone.
Therefore, I’m curious how exactly you plan to approach these difficulties. Do you use any tools like clamps or furniture lifters?
Please don’t take this the wrong way; I’m not trying to discourage you but to realistically outline the limits. But maybe there are clever solutions?
par41
25 Sep 2017 16:35
Svenja7 schrieb:
From my experience with Hemnes furniture, I can say the key is to systematically prepare each assembly group.
Thanks for the tip about systematic sorting! That really makes sense, especially since IKEA instructions often include many screws that look almost identical.
LuMarcel43 schrieb:
The actual assembly is only part of the challenge – handling the parts and securely attaching them to the wall often pose obstacles for those building alone.
That’s something I’m concerned about as well. I have a flat, stable wall at the location and plan to attach the cabinet directly to it. Unfortunately, I don’t have furniture lifters or clamps, but I do have some larger cloths to protect the surfaces.
Does anyone have tips on how to lean and align the cabinet against the wall alone without it falling over or damaging parts?
Also, how do you usually handle the back panel, which is quite large?
giabau
25 Sep 2017 17:05
The Hemnes wardrobe has a back panel that is often underestimated. To assemble it on your own, I recommend the following steps:
- First, sort all the boards and connectors.
- Assemble the main frame on a padded surface (e.g., a blanket or carpet) to avoid scratches.
- Roughly fit the large side panels and shelves together, but do not fully tighten the screws yet.
- Stand the wardrobe upright by carefully tipping it and supporting it against the wall with a cushion.
- Unroll the back panel and attach it initially to only one side.
- Important: The back panel should not be under tension; otherwise, it may warp.
- If possible, screw in the back panel step by step to prevent warping.
A cordless drill with adjustable torque is highly recommended to avoid overtightening screws.
