ᐅ How can I securely mount IKEA Hemnes shelves to the wall?
Created on: 29 Oct 2020 08:34
LOHAU
I am currently planning to install several IKEA Hemnes shelves in my living room, but I want to make sure that the shelves are securely and safely attached to the wall. Since the furniture feels quite heavy and I have young children at home, wall mounting is especially important to me.
My question is: How can I safely install IKEA Hemnes shelves on the wall?
Specifically, I am interested in:
- What fastening materials are recommended (e.g., anchors, screws, special brackets)?
- How can I best identify the right spots on the wall (e.g., whether the wall is concrete, drywall, etc.)?
- Are there any special tips or tricks for mounting Hemnes shelves that should be considered?
- Should the mounting hardware provided by IKEA be used, or are better alternatives recommended?
I look forward to your experiences and advice!
rekijan
29 Oct 2020 18:11
Great guide so far! I would also add that with Hemnes shelves, it’s important to secure the wall anchors not only at the top but, if possible, also stabilize the shelf at the bottom. This helps prevent tipping, especially if children are around.
Additionally, it makes sense to tap the wall with a small nail or drill bit before drilling to avoid hitting electrical cables – safety first!
And for those who are unsure: a simple stud finder is worth its weight in gold. It’s inexpensive and really adds safety when drilling.
Repar
30 Oct 2020 08:03
Ellis schrieb:
The safest method is to attach to load-bearing walls using heavy-duty anchors.
Exactly, this point is crucial. However, if you only have drywall, you need to rely on appropriate hollow wall anchors. Even better: try to locate the wall stud and screw directly into it.
Torsten45 schrieb:
Use screws at least 6cm (2.4 inches) long to ensure a secure hold.
That is important too. Short screws provide less support, especially for heavier shelves.
gauvin37
30 Oct 2020 09:27
I recently mounted three Hemnes shelves on a drywall. Using toggle anchors was essential for me – without them, it would never have held.
Other than that, the drilling templates included by IKEA save a lot of work, allowing you to drill the holes exactly in the right spots. Be careful when drilling to ensure the anchors grip properly.
kaju67
30 Oct 2020 17:21
rekijan schrieb:
If children are involved, this helps prevent tipping hazards.
That’s absolutely true! For families with children, I would recommend not only securing the shelves to the wall but also considering additional anchoring at the bottom, especially if the units are freestanding. A small word of caution to everyone: Although Hemnes shelves appear sturdy, they can tip over if overloaded or not properly secured to the wall—so be careful!
Overall, I’d say: wood or concrete walls? Great. Drywall? Use high-quality anchors. Children in the household? It’s better to take an extra step and add more fixing points. That way, nothing will go wrong.
LOHAU
31 Oct 2020 10:35
Thank you all for the helpful feedback.
At home, I mostly have load-bearing concrete walls, but there is also a drywall (plasterboard) wall in my study where I want to mount a smaller Hemnes shelf.
To summarize:
- For the concrete wall, I am using heavy-duty anchors and appropriate screws,
- For the drywall, cavity anchors or toggle bolts along with sturdy brackets,
- I will upgrade the standard IKEA mounting brackets with stronger screws,
- I am paying special attention to preventing the shelf from tipping over since there are children in the house,
- Careful measuring and marking are done with a spirit level and possibly a stud finder.
My only remaining question is: Are there recommended torque settings for tightening the screws to avoid damaging the anchors while still ensuring a secure hold?
Torsten45
1 Nov 2020 07:58
LOHAU schrieb:
Are there recommended torque values for tightening screws to avoid damaging the anchors but still achieve a secure hold?
Hello LOHAU,
Torque values are difficult to measure precisely in DIY situations, but as a guideline:
- When using a cordless drill, set the torque to a low level for tightening screws.
- You can usually feel when the anchor is secure and resistance increases while tightening.
- Over-tightening can damage the anchor, so it’s better to check frequently and tighten as needed.
For 8mm (5/16 inch) anchors, around 3–5 Nm (27–44 in-lb) is often recommended, but this can vary. A good practice is to tighten the screw firmly until it feels secure, then apply minimal additional force without turning abruptly.
With concrete walls, the risk of over-tightening is lower; with drywall, be more cautious.
If you have a torque wrench, you can use it, otherwise rely on feel and experience. In general: tighten securely but avoid over-tightening.
