ᐅ What are common mistakes when replacing BILLY hinges?
Created on: 23 Nov 2017 08:17
porter-na
porter-na
23 Nov 2017 08:17
I am planning to replace the hinges on my Billy shelf unit because one of them is broken. Before I start, I would like to know: what common mistakes occur when replacing BILLY hinges, and how can they be avoided? I’m especially interested in typical errors that DIY beginners or people with little experience often make—such as when removing the old hinges, fitting the new ones, or adjusting them. Are there any tools or tips that can help make the replacement process go smoothly? Thanks for sharing your experiences!
farkin
23 Nov 2017 08:45
This is a very practical question, thank you for that! Replacing the BILLY hinges, especially the metal hinges with dampers, is generally straightforward, but there are a few common pitfalls.
1. Completely removing screws instead of loosening them: Many people think they need to remove the old hinge entirely, but often it’s enough to first remove the door and then work on the cabinet body.
2. Incorrectly aligning or swapping screws for the new hinge: The BILLY hinge usually fits in only one position, yet sometimes screws are placed in the wrong holes, which are actually meant for additional strips or covers.
3. Missing adjustment: After installation, it’s often forgotten to adjust the hinge – this causes the doors to hang crooked or get stuck.
4. And very important: Don’t apply too much force on the screw connections, or they will tear out of the chipboard.
My tip: First, screw all screws in loosely and then check if the door fits properly before tightening them fully. A Phillips screwdriver of the correct size is also helpful since damaged screws are difficult to remove later.
Espen
23 Nov 2017 09:13
It is important to first remove the door before loosening the old hinges. Many people only unscrew the screws from the frame, but then the door remains hanging and becomes difficult to install. When installing, make sure the hinges snap in correctly.
tutan
23 Nov 2017 10:07
I think it’s important to stay relaxed! :-) Especially with the BILLY hinges, you don’t need that much force. You can easily control the tightening of the screws; otherwise, the wood can get damaged quickly.
farkin schrieb:
The doors end up crooked or sticking.
Exactly, so after replacing them, open and close the doors several times to allow everything to settle properly. A little patience pays off 😉
bijo54
23 Nov 2017 11:29
A common mistake is countersinking the screws too deeply. This does not hold well, especially in the particleboard of the BILLY shelves. Screws should always be tightened firmly but carefully.
MATHIASDO
24 Nov 2017 07:54
Interesting approach here, but I wonder: Why is adjustment often underestimated? It’s not just about tightening the screws, but about how the hinge is aligned to ensure, for example, an even door gap and to prevent stress on the material.
Additionally, after replacement, it’s important to check whether the hinge is truly the right model for the specific shelf. There are different versions available, and using the wrong hinge can reduce durability. I found some documentation on compatibility in the IKEA forum, which I would recommend checking before purchase.
