ᐅ Why do some Billy cabinet doors stick even though they appear to be properly hung?
Created on: 31 May 2022 10:07
Jillpu30Hello everyone,
I have a question that has been on my mind for a while: Why do some Billy cabinet doors stick, even though they appear to be properly aligned?
I mean, I have deliberately adjusted my Billy shelves straight and carefully, the hinges are correctly installed, and the doors seem to fit nicely. Still, they get stuck in certain spots when opening or closing. It’s not just a small squeak or the usual friction, but noticeably at specific heights where the door doesn’t move smoothly.
I suspect it might be related to the material properties or even humidity, but is that really the only reason? Or do you have experience with what else could cause this if both doors seem to be correctly and neatly assembled at first glance?
Thanks in advance for your opinions and tips!
Hello Jillpu30,
your observation is quite understandable. Even if the doors are hung correctly, several factors come into play. For one, wood-based materials expand due to moisture – especially with particleboard, which is used for Billy, small expansions can cause the doors to stick.
Additionally, the load placed on the doors or slight deformation of the shelves under weight can affect the fit.
My advice is to carefully readjust the hinges and regularly check if the screws are tight. If the apartment is damp, humidity can also be a critical factor.
blapau schrieb:
My advice is to carefully readjust the hingesBut why exactly? If the doors are hung properly, readjustments should generally not be necessary.
In my opinion, the problem starts earlier, with the choice of materials and manufacturing tolerances. Particleboard is prone to swelling and shrinking, especially in humid or fluctuating climate conditions.
From my perspective, the concept of “hung properly” does not automatically mean that binding points cannot occur. Perhaps it would be necessary to check not only the doors but also the entire cabinet for signs of warping?
farje schrieb:
If the doors are hung correctly, adjustments should normally not be necessary.Interesting point! I had personally checked that all screws were tight and that the doors appeared to be aligned parallel. But I feel this is a subjective assessment. Perhaps there is a more precise method?
tarju41 schrieb:
Whether the cabinet sides are truly flatCould you please explain briefly? How is this ideally measured? I just installed the cabinets using a spirit level.
Hello Jillpu30 and everyone following the discussion,
to return to the question: "Why do some Billy doors stick even though they seem to be properly hung?" – the issue is a bit more complex than it appears at first glance.
First: the material issue. Billy shelves are usually made of chipboard panels, which—as mentioned before—react to changes in humidity. Especially during transitional seasons or in kitchens and bathrooms, where moisture levels vary more frequently, the wood can swell.
Second: the hinge design. Billy uses so-called cup hinges, which allow some tolerance. Still, it can happen that the doors are slightly warped or that the frame is not perfectly plumb. Therefore, "properly hung" does not always mean "functioning perfectly."
Third: the surface or installation situation. Even when checked with a level, the wall itself can be slightly uneven, or the furniture might be standing on an uneven floor – this can affect how the door behaves.
My advice: Check the moisture condition of the furniture, systematically verify the levelness of both the cabinet body and the doors, and examine the hinges for possible adjustment options. Often, small adjustments can significantly improve the problem.
