ᐅ Why do some Billy cabinet doors stick even though they appear to be properly hung?
Created on: 31 May 2022 10:07
Jillpu30
I have a question that has been on my mind for a while: Why do some Billy cabinet doors stick, even though they appear to be properly aligned?
I mean, I have deliberately adjusted my Billy shelves straight and carefully, the hinges are correctly installed, and the doors seem to fit nicely. Still, they get stuck in certain spots when opening or closing. It’s not just a small squeak or the usual friction, but noticeably at specific heights where the door doesn’t move smoothly.
I suspect it might be related to the material properties or even humidity, but is that really the only reason? Or do you have experience with what else could cause this if both doors seem to be correctly and neatly assembled at first glance?
Thanks in advance for your opinions and tips!
farje
1 Jun 2022 11:41
Lamar schrieb:
We expect perfection, but get served a kind of 'functional compromise'.
I agree to the extent that all industrially manufactured furniture inevitably involves compromises – the materials used, cost limits, and manufacturing tolerances do not allow for perfect fitting.
However, "binding even though properly assembled" is not an acceptable condition from the customer’s perspective, but a defect that should at least be significantly reduced through adjustability.
This means that "hanging correctly" and "functioning smoothly" are two different things that we must not confuse.
blapau
1 Jun 2022 12:05
Lamar schrieb:
A deliberately created problem tolerated by the manufacturers
I don’t really agree with that. While such suspicions are appealing, quality standards in the furniture industry are usually high, and complaints cost the manufacturer more than fine-tuning on site with the customer.
The problems more likely result from the natural characteristics of wood-based materials, manufacturing tolerances, and everyday use.
A certain amount of readjustment is completely normal—similar to a car that requires minor adjustments after some time.
Perhaps “sticking” should not be seen as a defect but rather as a signal for maintenance.
lubla
1 Jun 2022 17:36
For me, sticking is often a sign of moisture exposure.
I have noticed in my apartment that during damp seasons the doors are harder to open, but become easier again in winter.
Ventilating, heating, and adjusting the hinges when necessary have helped me.
Jillpu30
2 Jun 2022 09:04
Thank you very much for the detailed feedback!
I will soon remove my doors and check them for dimensional accuracy, recheck the cabinet walls with a spirit level, and inspect the hinges more closely. It seems to be a combination of material properties (moisture, temperature fluctuations), small manufacturing tolerances, and installation details.
Your input has helped me to understand the issue more clearly. I will of course share any new insights here 🙂
