ᐅ What can you do if the IKEA Hemnes wood is chipped or damaged?
Created on: 20 Aug 2017 09:47
pepete
pepete
20 Aug 2017 09:47
I have a rather specific question regarding my IKEA Hemnes wooden dresser. I noticed a crack has developed on one of the larger surfaces, more precisely on the side panel. The material appears solid, but I suspect it might be some type of MDF with a real wood veneer or solid wood facing.
My question is: What is an effective way to repair cracks in IKEA Hemnes wood? I’m especially interested in solutions that allow for a stable and visually pleasing repair without having to replace the entire piece.
For those with DIY experience: Which products or techniques would you recommend?
I hope someone has practical tips or experience with this kind of damage on the Hemnes series. Thanks in advance!
klo40
20 Aug 2017 11:02
Hello pepete,
Your question about "What helps when IKEA Hemnes wood is cracked?" is very well posed and allows for targeted answers. I’ll provide a structured guide on how to approach this.
- First, check how deep and wide the crack is. Is it just a surface split, or does the crack go through the entire piece of wood?
- For smaller cracks, a flexible wood filler or high-quality wood putty is recommended. Be sure to match the color to the Hemnes wood, which is usually a light pine tone.
- Before applying, carefully clean the area and, if needed, lightly sand the edges with fine sandpaper to help the filler adhere better.
- After drying, sand gently and treat the surface with appropriate furniture wax or a clear, colorless varnish.
- If the crack is deeper, you can insert wooden dowels or small veneer pieces using white glue and then fill over them.
Common mistakes: Applying varnish too quickly before the filler is fully dry, or sanding too aggressively, which makes the repair visible.
Summary: It depends on the extent of the damage, but usually, with filler, sanding, and finishing treatment, you can achieve a good result.
If you have detailed questions about materials, just ask!
trevor
20 Aug 2017 14:37
klo40 schrieb:
Typical mistakes: Painting too quickly without allowing the filler to fully dry, or sanding too roughly, which makes the repair noticeable.
That really hits the nail on the head! Have you already tackled the crack issue, pepete? I would also recommend having a bit of patience.
A small tip from everyday DIY life: Sometimes it helps to slightly dampen the area beforehand so the filler absorbs better. Be careful not to make it too wet! 😅
And yes, such a crack is annoying, but usually you can fix it quite well with simple methods.
So, don’t get discouraged, keep applying the filler from time to time, and the piece of furniture will live on. 👍
meson
21 Aug 2017 07:19
If the crack is deep, unscrew the screws, apply wood glue into the crack, press it slightly, and let it dry. Then sand and blend the color to match.
Tarmau
21 Aug 2017 18:53
pepete schrieb:
What is an effective way to repair a crack in IKEA Hemnes wood furniture? I am especially interested in whether there are methods to stabilize and make the crack visually appealing without having to replace the entire piece.
Regarding repairing cracks in Hemnes furniture made of solid wood or wood-based materials, I recommend the following approach:
- Identify the material: Hemnes is typically made of solid pine wood with a light lacquered finish. This affects the repair methods.
- Cracks should be treated with wood glue (preferably polyurethane glue for lasting adhesion). Apply the glue into the crack, then clamp or press the parts together to close the gap.
- For visual matching, either wood filler or color-matched touch-up markers are suitable.
- Complete sanding and repainting are often not necessary but can be useful for deeper damage.
- Cracks often occur due to moisture fluctuations, so proper storage and climate control should be considered to prevent further issues.
- Replacing damaged parts usually makes sense only if structural stability is compromised.
A precise and targeted repair saves both cost and effort. I recommend using professional-grade products designed for pine wood, available from specialized retailers.
