ᐅ What to do if the edges of an IKEA HEMNES wardrobe are damaged?
Created on: 5 Nov 2021 09:13
benedicton
I recently received an IKEA Hemnes wardrobe, and unfortunately, I noticed some damage to the edges during unpacking and assembly. The damage includes surface scratches as well as small cracks and dents on the wood edges.
Since I would like to keep the wardrobe, I am wondering how to best repair or conceal these typical edge damages without having to replace the entire piece.
Do you have experience with suitable products or techniques to carry out a visually appealing and durable repair on the rather delicate edges of the Hemnes wardrobe?
Tips on recommended products (such as special wood fillers, touch-up markers, repair kits) would also be appreciated, as well as advice on whether it’s better to seek professional help or if it can be done well as a DIY project.
Thank you in advance for your support!
Meoru
6 Nov 2021 12:05
Good idea from fikeo!
I would also recommend treating the edges with furniture wax after the repair. This keeps the surface flexible and protects against new damage.
LANICOLE
7 Nov 2021 07:33
Hello benedicton,
let me offer you a small step-by-step tutorial that can help you repair the damaged edges of your Hemnes cabinet:
- Step 1: Damage Assessment
Carefully examine the type of damage: scratches, dents, or cracks. Make a note of these.
- Step 2: Preparation
Lightly sand the edges to remove loose paint or splinters. Use fine sandpaper (grain 220).
- Step 3: Filler Application
For cracks and dents, use a high-quality, solvent-free wood filler. Smooth the filler with a putty knife and let it dry (minimum 2-4 hours).
- Step 4: Fine Sanding
After it has fully dried, sand the repaired area smooth again.
- Step 5: Color Matching
Use a furniture touch-up pen in a matching color to retouch the repaired area. Test the result first on an inconspicuous spot.
- Step 6: Sealing
Then apply a matte clear coat to make the surface more durable.
- Step 7: Care
After drying, optionally treat the edges with furniture wax or wood oil.
Mistakes to avoid:
- Using sandpaper that is too coarse, which could further damage the edges.
- Applying color too quickly before the filler has completely dried.
- Using colors that do not match and stand out immediately.
Good luck! If you have any questions, I’m happy to help.
barEsperan
7 Nov 2021 11:14
If the edges are heavily damaged, it can also be worth checking replacement parts. IKEA sometimes replaces parts if the damage was caused during delivery.
fiman
8 Nov 2021 09:47
I have always used simple wax crayons on my HEMNES. If you like the color, it lasts for several months. Don’t forget to maintain it.
MUMENAR
8 Nov 2021 12:03
This is an important point. It is essential to check if the damage is covered under the warranty or return period. Often, repair is the practical solution, but sometimes a free replacement is the better option.
Has benedicton already contacted IKEA regarding the edge damage?
