ᐅ What repairs can I do myself on IKEA Hemnes furniture, and when should I seek professional help?
Created on: 16 Jun 2015 07:23
Tarix67
Tarix67
16 Jun 2015 07:23
Hello everyone, I recently bought some furniture from the IKEA Hemnes series – including solid wood dressers and nightstands. Now I’m wondering: What kind of repairs can I realistically do myself if these Hemnes pieces get damaged or start to become wobbly? And at what point should I call in a professional, like a carpenter or woodworker? I have basic DIY skills—I can drive screws and assemble furniture—but I’m unsure when it comes to wood repairs, more significant damage, or possibly replacing parts. Maybe some of you have experience with what’s doable for amateurs and which mistakes to avoid? Thanks in advance!
Guyju
16 Jun 2015 08:57
Hi Tarix67, your question is very practical! Basically, the Hemnes furniture from IKEA is quite sturdy and modular, which makes repairs easier.
- Minor issues like loose screws, squeaking tracks, or torn-out dowels can usually be fixed by yourself without any problems. Tightening or replacing screws, possibly inserting new dowels – this is usually straightforward.
- For surface scratches or small dents in the solid wood, you can often improve the appearance with wood filler or wax. It is important to match the wood color correctly here.
- It becomes more difficult with cracks in the wood or if the fastenings on visible edges are loose. In these cases, you should carefully check whether the piece of furniture still holds together securely.
- If load-bearing elements are broken, or if you want to reconstruct the furniture, this is more a job for professionals.
It is always important to proceed carefully and ask for advice or seek professional help if unsure, in order to avoid further damage. I hope this helps you for now!
chentan
16 Jun 2015 09:37
Hello Tarix67, I’m happy to go into detail since you mentioned basic practical skills. To answer your question as thoroughly as possible, here is a detailed overview:
1. Material and Construction: Hemnes furniture is made from solid woods such as pine or birch. Solid wood requires a different approach than chipboard or MDF.
2. What can you do yourself?
- Tighten screws if joints become loose.
- Replace small fittings like hinges and handles – IKEA provides replacement parts.
- Surface treatment, e.g., sanding and oiling to fix minor scratches.
- Renewing dowels: if dowels are torn out, you can insert new ones with wood glue.
3. More difficult tasks:
- Repairing cracks in solid wood (you will need sanding tools, wood glue, clamps).
- Regluing load-bearing joints.
- Repairs that affect the stability of the furniture.
4. Professional help needed for:
- Heavily damaged wooden parts that need to be cut or replaced.
- Furniture with built-in mechanisms (drawer runners) if more complex components are broken.
- Restoration work where the appearance must be perfectly preserved.
My question to you: What kind of damage have you experienced so far? That will help tailor the advice better.
parbau
16 Jun 2015 10:48
Hey Tarix67!
You’ve raised a good question, and I believe that with a bit of courage and the right tools, you can handle quite a bit yourself when it comes to Hemnes furniture. Of course, it depends on the damage, but I would say:
- Scratches? A bit of sandpaper and wax—easy.
- Wobbly legs? Tighten the screws and stabilize with (not too much!) glue.
- Larger gouges or broken parts? Personally, I’d recommend professional help for those.
After all, you don’t want your nighttime pile of books to take off faster than your next flight to Ikea 😉
Patience and regularly checking if everything is still aligned—this way, repairing can even be enjoyable!
O
onfebe
16 Jun 2015 11:13
Hello Tarix67, I understand that you feel a bit uncertain, especially when it comes to valuable pieces of furniture that motivate you to repair them yourself in the future.
The Hemnes series is really sturdy, and small repairs can be handled – that builds confidence. But with bigger damages, it definitely makes sense to get some help to avoid frustration and failed attempts.
I have personally experienced trying to repair a cracked particleboard carcass, which didn’t work out, and I eventually had to call a carpenter.
Trust your instincts: if you’re unsure about a repair or the stability seems compromised, that’s a good sign to seek professional help. There’s no shame in it, and it also protects your furniture and your budget.
LENNAU
16 Jun 2015 13:02
Hello Tarix67,
I would like to reinforce some basics: The Hemnes furniture is designed so that many joints are made with screws, wooden dowels, and sometimes metal fittings. This makes them easier to repair yourself, as long as you know where to start.
In my opinion, you need a professional for:
- Completely broken wooden parts (e.g., legs)
- Furniture warped by moisture
- When stability is significantly compromised and you need to alter the structure
You can do yourself:
- Tighten or replace screws
- Re-glue or replace dowels
- Touch up surfaces with wood stain or wax
One more tip: Use all the provided assembly instructions, as they can also help with repairs. Good luck!
