I would like to start a new thread regarding the initial design planning.
Previous thread: Single-family house – Opinions on our design
https://www.hausbau-forum.de/threads/Einfamilienhaus-Meinungen-zu-unserem-Entwurf.25622/
Here are the main points:
The foundation slab is already in place: 12.49 x 12.49 m2 (41 x 41 ft2) and 30 cm (12 inches) thick.
The foundation slab was inspected for quality by an energy consultant and a structural engineer – no issues were found.
The locations of the underground drainage pipes are marked in the image titled "Foundation Slab - Drainage Pipes."
The house is planned to be built on the existing foundation slab. Demolition is not planned.
The house needs to be constructed as a one-story plus attic (E+1) with a gable roof at a 22° pitch.
The original submission plan from the previous owner was applied for but has not been received yet.
Our own submission plan from the architect exists but was mostly rated as unsatisfactory.
Negative points in the submission plan:
Our specific requests:
We like the ground floor and its room layout quite well. However, the half-landing staircase should be replaced by a space-saving alternative.
The staircase was placed centrally to allow the desired rooms to be created.
• Development plan / restrictions
Plot size: Parcel 35, 775 m2 (8,835 ft2)
KFW 55 standard
Slope: Yes
Site coverage ratio: 0.35
Floor area ratio: 0.80
Building envelope, building line, and boundary: see site plan
Edge development: No
Number of storeys: 2
Roof style: Gable roof, 22° pitch
Style / orientation: South - southeast
Maximum dimensions/limits: Building maximum = 14 m x 10 m (46 x 33 ft) plus single-story extension with max. length 10 m (33 ft), max. depth 3 m (10 ft)
Client requirements
Style, roof type, building type: Gable roof, 22° pitch
Basement, storeys: No basement, 2 full storeys
Number and ages of occupants: 4 persons (3 females, 1 male), ages 40, 38, 12, 9
Space requirements on ground and upper floors: Since no basement, more space per floor needed → approx. 90 m2 (970 ft2) per floor
Office use: Home office planned, possibly later converted to a bedroom / guests about 6 times a year
Open or closed layout: Open layout, at least on the ground floor
Traditional or modern design: Modern design
Open kitchen with island: Yes, open kitchen with cooking island
Number of dining seats: 1
Fireplace: Yes, should be placed in the living room, as the chimney should not pass through the children’s bedrooms.
Music / stereo wall: No
Balcony, roof terrace: Balcony: yes, roof terrace: no
Garage, carport: Double garage with partition
Additional wishes / special features / daily routine explanations:
Photovoltaic system + possibly battery storage, active ventilation system with heat recovery, air heat exchanger, cistern
Planner: Architect
- Company planner: No
- Architect: Yes
- DIY: No
What do you especially like? Why? Ground floor thanks to the open design with large windows
What do you dislike? Why? Upper floor layout
Estimated price according to architect/planner: ?
Personal budget limit for house including fixtures: 400,000 €
Preferred heating technology: Air heat exchanger with underfloor heating
If you had to give up something, which details or features could you do without?
- Can give up: Battery
Cannot do without:
Not a standard design from the planner, ideas based on model houses + floor plans found online + architect input
How can I improve the layout of the house?
- Ground floor + upper floor
- Staircase between ground and upper floor is not properly dimensioned
- Ground floor
- Staircase unsuitable, takes up too much space; entrance to living area is through the kitchen
- Access from garage to house does not fit due to height differences
- Upper floor
- Staircase unsuitable, room layout and a dark hallway with hallway width only 1.10 m (3.6 ft)
- Balcony extends across the entire house length
- See east elevation under the image “View all sides”
- The balcony was extended because the upper floor protrudes 70 cm (28 inches) beyond the ground floor, covering the resulting overhang. In the previous plan, the balcony was only above the bay window.
- Keep the technical room in the marked position for connection reasons, near the turning circle.
- Keep the front door position as shown – access from the garage plus guests parking in front of the garage.
- Central staircase to maintain short walking distances.
- Type of staircase: corner staircase with quarter turns (1x or 2x 90° turns) or straight staircase. Spiral staircases are not desired.
- Modern house with an open kitchen and living area.
- Home office.
- Guest toilet with shower.
- Pantry for freezer, food, and beverages.
- Large children's bedrooms, preferably on the south side.
- Room for a walk-in dressing area.
- Separate entrance to the master bedroom, not through the dressing room.
- One master bathroom and one children’s bathroom.
- Small utility room (approx. 6–8 m2 (65–86 ft2)) on the upper floor for washing machine and dryer.
- Tiled stove; the chimney flue should not run through the children’s bedrooms. Preferred route is through the bathroom or utility room.
KFW 55 standard
Slope: Yes
Client requirements
Planner: Architect
- Architect: Yes
- DIY: No
Cannot do without:
At least, you can see clear changes. I would not position the children's room doors so close to the wall but leave some space behind them for shelves.
I think it’s great except for the chimney.
I’m not really a fan of the open void either, as it makes the house feel even less calm. Starting the staircase in the living room is quite bold. With the open ceiling, of course every little noise from above reaches the living area directly.
Still, I find it very well done.
I would reconsider the layout of the bedroom, walk-in closet, and master bathroom. As it is, you have to go through the bedroom to get from the closet to the bathroom and vice versa. This means if one person wants to sleep longer, it can be quite inconvenient.
I’m not sure where north and south are oriented in this plan. Possibly, I would also consider swapping the children’s bathroom with the utility room.
The doors in the children’s room seem fine as they are since there is enough space for wardrobes and shelves otherwise. What I don’t like is when there’s space behind a door but not enough for a closet or shelf—that’s wasted space. So, this layout is absolutely acceptable.
Overall, I think there’s a lack of storage space. You don’t have a basement, the technical room on the ground floor isn’t very large and loses floor space due to the garage access (is that really necessary?). There’s also no pantry anymore. Where is all the stuff for a family of four supposed to be stored? I just don’t see it…
Climbee schrieb:
I would reconsider the layout of the bedroom, walk-in closet, and master bathroom. As it stands, you have to go through the closet to get to the bedroom and bathroom, and vice versa. This means if one person wants to sleep longer, it can be quite inconvenient. Oh no! Access to the bedroom through the walk-in closet or something similar is completely out of the question. You’re not the first to feel this way. Does anyone else understand this?
Climbee schrieb:
Overall, I think there’s a lack of storage space. You don’t have a basement; the utility room on the ground floor isn’t very large and loses usable space due to the garage entrance (is that necessary?). There’s no pantry anymore either. Where is all the stuff for a family of four supposed to be stored? I don’t see it anywhere... I think it’s okay. The kitchen is large. That huge work island in the middle, by my estimate, alone contains space for 10 base cabinets. You can definitely store a lot there. Of course, the question is whether the original poster planned it that way. But at least it’s possible.
Climbee schrieb:
I would reconsider the layout of the bedroom, walk-in closet, and master bathroom. As it stands, you have to go through the walk-in closet to get from the bedroom to the bathroom and vice versa. That means if one person wants to sleep in, it can be quite inconvenient.
...I’ve mentioned this three times (once with a metaphor that none of the men here could relate to).
I’m also missing storage space.
I like the idea of switching the kitchen and living room.
The open space is nice, but it conflicts with having a stove there. Fire and air come together in one square meter, which doesn’t work well.
